Let's see your cb antenna location.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DEEVON911, May 4, 2013.
  1. May 4, 2013 at 9:38 AM
    DEEVON911
    DEEVON911 [OP] Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I'd like to see the locations you guys put your cb antennas. I'm torn where I would like to put it on my truck, so I'd like to see all the places people have put theirs. I like the mount by the tailgate, but still not sure.
    Also, when you post, any positives or negatives to where you put it.
    Thanks in advance!
  2. May 4, 2013 at 10:12 AM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
  3. May 4, 2013 at 10:21 AM
    DEEVON911
    Dave
  4. May 4, 2013 at 10:22 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    No pics with the antenna on it other than this (Wilson 5'). Just installed it last weekend and will install CB & ARB OBA next weekend.
    On a Relentless hood mount bracket.
    And yes you can still open the hood with it.
  5. May 4, 2013 at 10:45 AM
    DEEVON911
    Dave
    Thanks, I like that spot too. That bother you while driving at all, or in your line of sight?
  6. May 4, 2013 at 11:47 AM
    4Wheelin4Banger
    Randy
    You'll see it, but it doesn't bother me.
  7. May 4, 2013 at 12:57 PM
    DEEVON911
    Dave
    Gotcha, thanks.
  8. May 4, 2013 at 1:02 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    I'd just do the tailgate spot. That mount Steve's got is like $20 online
  9. May 4, 2013 at 1:28 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I have mine on the roof using a Wilson lil will mag mount. I have the coax going behind the third brake light assembly and into the cab...making it a semipermanent mount. I've had this antenna for well over ten years now and still no problems (used to be on my old Montero Sport)..a roof mounted antenna will have the best ground plane and yeilds best results..
  10. May 4, 2013 at 6:41 PM
    DEEVON911
    Dave
    Yeah, I'm thinking about it, did you see Famous fab is gonna make the tailgate ones again?
    Thanks Monkey, food for thought.
  11. May 4, 2013 at 6:43 PM
    Monster Coma
    Corey
    Yes I did however free/the price of some beers is better than $30 lol
  12. May 4, 2013 at 6:48 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
  13. May 4, 2013 at 6:56 PM
    DEEVON911
    Dave
    LOL, true. The hood mount one is $20, so I'm thinking of that now.
    I like that spot, thanks. I have a tonneau cover though.
  14. May 4, 2013 at 6:59 PM
    Monster Coma
    Corey
  15. May 4, 2013 at 7:12 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    ^^^What he said. Put a mag mount on the roof for max performance. If you want a hard mount, then the hood mount is the second best solution.
  16. May 4, 2013 at 10:33 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Mine was 3.15 at the Home Depot! I wandered one day when I wasn't happy with the crappy stock mount.
    http://www.homedepot.com/p/Simpson-Strong-Tie-Angle-A24/100375162?N=aq8i#.UYXtHr95nzI
    All i had to do was drill two holes in order to Bolt onto the Back of the Bed, near the tailgate. The metal bracket provides a GREAT ground connection to the bed bolts, the same two bolts that the BAMF mount bolts to.
    http://www.tacomaworld.com/forum/ba...2-bamf-2nd-gen-tailgate-cb-antenna-mount.html
    It puts the mount level with the edge of the tailgate. You can round off the corners if you have an angle grinder or dremel. I added a quick disconnect so I can still get into parkin garages at school.
    Other than that I love it. Super sturdy, great ground. I have a 1.1:1.2 SWR for my Firestik 4'.
  17. May 5, 2013 at 3:47 AM
    DEEVON911
    Dave
    Also, where did you bring the cable into the cab with this spot?
    Can't beat the price, you mind posting up a pic of it on your truck?
  18. May 5, 2013 at 4:06 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I am using a Relentless hood mount. Easy coax routing.
    I used to have it on a door jamb mount between the tailgate/bedside. The relentless products were on sale so I decided to get his mount.
  19. May 5, 2013 at 4:14 AM
    DEEVON911
    Dave
    Nice, thanks. Where did you run your coax into the cab with the hood mount?
  20. May 5, 2013 at 6:00 AM
    ajohnson
    Andy
    Charlotte, NC
    There is a large rubber boot in the driver's side of the firewall, next to the steering shaft. I poked a hole in it and pulled the wire through that. I left the PL-59 connector off of my Firering coax until I pulled it through.
