Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Nov 2, 2018 at 11:46 AM
    #321
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thanks Craig. I just might take you up on that.
  2. Nov 2, 2018 at 12:22 PM
    #322
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  3. Nov 2, 2018 at 3:19 PM
    #323
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Well fellas... I believe my new rear Diff is broken.
    I think a 9” is more important than a Marlin right now.
  4. Nov 2, 2018 at 4:14 PM
    #324
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    How’d you manage that?
  5. Nov 2, 2018 at 4:19 PM
    #325
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I think it’s the Supercharger. I don’t know. I was doing WOT data logging to send to Scott (UCON tuning guy) yesterday morning on my way to work.
    I mean, I drove all the way home from Moab without issue. I obviously didn’t break it out there.
    Must be the Supercharger.
  6. Nov 2, 2018 at 4:27 PM
    #326
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Auto trans & 4.88 gears correct?
  7. Nov 2, 2018 at 4:36 PM
    #327
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yup
  8. Nov 2, 2018 at 5:06 PM
    #328
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Low mileage 4.88s lol
  9. Nov 2, 2018 at 5:52 PM
    #329
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Sent an email to RST. They said some input shaft play is normal for the FJ case. Glad to hear that!
    hoverlover, MY50cal and 6 gearT444E like this.
  10. Nov 2, 2018 at 6:30 PM
    #330
    6 gearT444E
    Deep South
    Herculiner Hootus
    I'm willing to bet you put a small hair fracture in one of the teeth at Moab and it didn't show it's head until now. Same thing happen to me a few years back, went wheeling a month before hand and had no issues, was driving on the road normal driving back from VA and heard the infamous sound of the frequency of a broken ring gear hitting the pinion head.
  11. Nov 2, 2018 at 6:58 PM
    #331
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That’s very likely. I did have a couple of cringe inducing bounces out there.
    It’s funny. The sound is a rotational thumping this time. Last time it was a crunchy grinding sound.
    I did verify that it’s coming from the diff with a stethoscope.
  12. Nov 4, 2018 at 12:08 AM
    #332
    Jcapen
    Jcapen Active Member
    2014 Tacoma Dbl Cab 4x4 6sp Man
    Homer, last I check marlin wasnt offering the crawl box for 2nd gen tacoma manual transmission. They are having an issue with the adapter plate that cause increase oil volume leading to oil coming out of the shifter. Last I checked they were testing a proto type.
    HomerTaco likes this.
  13. Nov 4, 2018 at 12:17 AM
    #333
    Jcapen
    Weldo, open the case in 2wd snd pull it apart very carefully and slowly because aou can pull the shift rods out of their slots and a little ball bearing will fall out. In order to get that back where it belongs you have to pull the gear off with those little keys (blocks). No worries though because if I can figure it out with zero experience anyone can. I probably put those keys in and out 10 times trying to figure it out. Gets easier with practice ;). Worse case senario you learn a lot more about how the case goes together then you bargained for.
    dborrer, MY50cal, weldo and 1 other person like this.
  14. Nov 4, 2018 at 5:01 AM
    #334
    weldo
    Pittsburgh, pa
    Thanks for the advice! I haven't found a super good walk through of installing the twin stick shifters yet. Can anyone who has them say if they came with instructions?
    hoverlover likes this.
  15. Nov 4, 2018 at 5:07 AM
    #335
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There aren’t any since the RTS forum is gone.
    We winged it with my install. :oops:
    Helps to have someone there who’s done it before.
  16. Nov 4, 2018 at 5:11 AM
    #336
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Does this help?
  17. Nov 4, 2018 at 7:11 AM
    #337
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  18. Nov 4, 2018 at 9:48 AM
    #338
    weldo
    Pittsburgh, pa
    Yooda man! Thanks dude that will be very helpful!
    SMKYTXN likes this.
  19. Nov 7, 2018 at 6:32 PM
    #339
    Jcapen
    Soooooo, Ive been procrastinating about wiring my ADD switch because I figured it was the "easy" part and I haven't had time to go out anyway. Well, the time has come and Im going out. I have the pre-built switch from RST. Plugs right into the ADD and all I have to do for the other end is give it power and find a ground. Wyatt said get the power from the 4wD fuse in-cab, drivers side. This is the part where I feel stupid, how do I do that? I took apart down to the fuse box, unmounted it and its far more complicated and closed up than I anticipated....Should I just get a wired fuse from a stereo store and do it that way? Thanks in advance.
  20. Nov 7, 2018 at 7:16 PM
    #340
    weldo
    Pittsburgh, pa
    A fuse tap is probably the easiest way to go. Should be able to find one at any auto parts store.
    Or you could find a wire that's hot and splice into it. The fuse tap is a lot less invasive though.
