Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Nov 3, 2020 at 8:15 PM
    #1241
    Dex__43
    Dex__43 Well-Known Member
    Sam
    KCMO
    09 DCSB TRD OR 4x4 Swap
    4x4 Conversion 2.5 inch lifts with 33's Sliders Skids Front Runner racks Satoshi grill Patches and Stickers BAMF hybrid front HC tube rear Light bar 2 Hella's behind the grill Pioneer media player and subs Sleeping platform with lower storage for the bed
    No way! Well now I know
  2. Nov 4, 2020 at 5:13 PM
    #1242
    Dex__43
    Sam
    KCMO
    So what if a tcase doesnt come with the shifter?
  3. Nov 4, 2020 at 5:18 PM
    #1243
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Buy a stock one from the dealer, find one at a junk yard, or get twin sticks
  4. Nov 4, 2020 at 5:22 PM
    #1244
    Dex__43
    Sam
    KCMO
    How hard is it to modify for twin sticks?
  5. Nov 4, 2020 at 5:27 PM
    #1245
    hoarder23
    Shay
    NJ
    Scratches
    Ideally you should feel comfortable cracking the case open, but you can do it from the top if you are careful. You just need to grind down one of the rails and remove a detent pin.
  6. Nov 4, 2020 at 5:57 PM
    #1246
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    It’s not really worth the effort TBH. You can just leave the ADD if 2lo is what you’re after
  7. Nov 4, 2020 at 7:16 PM
    #1247
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    In some cases, but some people are removing the ADD entirely
    I have a solid shaft from a GX470, so my front is always engaged
  8. Nov 4, 2020 at 8:47 PM
    #1248
    Dex__43
    Sam
    KCMO
    Please tell me more. I'm trying to track down one from a manual fj but I cant find one that's not attached to the diff still
  9. Nov 4, 2020 at 10:55 PM
    #1249
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    What do you mean, "not attached to the diff"?
    The transfer case for the manual transmission fj has a planetary gear in the transfer case so it works 4x4 all the time. You just lock the transfer case when you hit the dirt and it acts like a traditional transfer case at that point.
    Added info. The manual fj case allows different speed to the front and rear axles, "like a diff does to left and right wheels" it is all mechanical.
  10. Nov 4, 2020 at 10:59 PM
    #1250
    hoarder23
    Shay
    NJ
    Scratches
    He means he can't find a tube that is not sold as a unit with the front differential (diff) from an FJ. This makes sense as most people would want the full setup, not just the tube.
    The tube he wants goes from the front diff to the passenger CV
    rheath08[QUOTED] likes this.
  11. Nov 4, 2020 at 11:08 PM
    #1251
    rheath08
    Russell
    Bakersfield, CA
    Ah! Hell I'm still looking for the tube. Not from the factory. Cause after the tube, bearings, seals, etc it way too much. I just manually slide my tube to the engaged side then put a worm clamp the the shaft and put the add back on.
  12. Nov 4, 2020 at 11:23 PM
    #1252
    6 gearT444E
    Deep South
    Herculiner Hootus
    “too much?” You’re talking under $300, that’s less than most people spend on beer in a week.
  13. Nov 5, 2020 at 5:40 AM
    #1253
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lulz
  14. Nov 5, 2020 at 6:50 AM
    #1254
    rheath08
    Russell
    Bakersfield, CA
    Still have you buy the bearing and the seal. But I had already spent a lot of money on the conversion, did not want to spend any more. I have not gotten around to do it since.
  15. Nov 5, 2020 at 7:40 AM
    #1255
    Dex__43
    Sam
    KCMO
    That post was not talking about the transfer case anymore. That was talking about the diff tube or intermediate shaft part.
  16. Nov 5, 2020 at 4:01 PM
    #1256
    6 gearT444E
    Deep South
    Herculiner Hootus
    you don’t have to do the bearing. You can read my write up here for costs. And you can sell that crappy ADD setup to some poor sap who’s stopped working
    https://www.tacomaworld.com/threads/how-to-deleting-add-system.427258/
  17. Nov 10, 2020 at 4:26 PM
    #1257
    DaytonaTaco
    DaytonaTaco Well-Known Member
    2015 Tacoma Sport 4x4 access cab 6spd w/ tow package
    Does anyone know how the wiring schematics work (for behind the glovebox) for a 2015? The instructions stop at a 2011 model.
  18. Nov 10, 2020 at 4:35 PM
    #1258
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  19. Nov 10, 2020 at 4:35 PM
    #1259
    BassAckwards
    I used the 08-11 wiring on my 13 and it was exactly the same
  20. Nov 10, 2020 at 4:36 PM
    #1260
    DaytonaTaco
    Awesome. Now I just have to figure out what that stuff means lol. I feel like I’m looking at hieroglyphics
