Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Sep 2, 2018 at 6:16 PM
    #161
    Jcapen
    Jcapen Active Member
    2014 Tacoma Dbl Cab 4x4 6sp Man
    Im sure if you called or e-mailed RST they would supply you with the wiring diagram. Can't hurt to ask. I think the harness is a little over 100 dollars. I honestly can't remember exactly.
  2. Sep 2, 2018 at 6:26 PM
    #162
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The harness diagram was a napkin drawing, but worth asking
  3. Sep 2, 2018 at 6:54 PM
    #163
    tacomonster23
    tacomonster23 Well-Known Member
    06 Taco
    Hey guys, I just purchased my fj transfercase the other day and planning on doing this sometime this week. Anybody have any advice? I have an automatic 06 access cab trd offroad
  4. Sep 2, 2018 at 7:01 PM
    #164
    Jcapen
    Take the cases apart carefully, or you will learn a lot more about the internals than you care too.
    ToyotaRoamer86 likes this.
  5. Sep 2, 2018 at 7:02 PM
    #165
    tacomonster23
    06 Taco
    Why do need to take the fj tcase apart?
  6. Sep 2, 2018 at 7:03 PM
    #166
    Jcapen
    Guess you don't because you are automatic
  7. Sep 2, 2018 at 7:05 PM
    #167
    tacomonster23
    06 Taco
    Yeah I was under the impression it was a bolt on fix. And how do you do the ADD delete? Would I still need to mess with any electronics besides the lights?
  8. Sep 2, 2018 at 7:11 PM
    #168
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Without the electronic actuator in the stock case the FJ case will require wiring for the dash lights to operate properly. When you eliminate the dash 4wd switch you need to install a new switch to activate the front diff for 4wd as the stock switch removal will disable that function. You'll need to manually activate with the case swap.
  9. Sep 2, 2018 at 7:27 PM
    #169
    Jcapen
    You can only do a true ADD delete by swappin diff tubes or SAS.
  10. Sep 2, 2018 at 7:39 PM
    #170
    tacomonster23
    06 Taco
    You're eliminating the 4wd switch because you need the switch sensor wires for the dash lights?
  11. Sep 2, 2018 at 7:42 PM
    #171
    hoarder23
    Shay
    NJ
    Scratches
    No, you are eliminating the 4wd switch because you no longer have an electric actuator on the transfer case. You need a switch to activate the front diff ADD after the install
    HomerTaco likes this.
  12. Sep 2, 2018 at 7:52 PM
    #172
    Jcapen
    When you turn the dash switch it does two things, engages the front ADD and shifts the acuator on the T-case to 4wd. When you take the electronic case out you will be unplugging the t-case acuation part of this loop making that switch useless. All the wires to make the dash lights work are located at the 4wd ecu behind the glove box. You have to cut and splice 4 wires making that loop further useless.
    Biscuits and HomerTaco like this.
  13. Sep 3, 2018 at 4:38 AM
    #173
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    What did you guys end up doing with the empty switch slot? That info is down the important-things-to-figure-out list a ways, but curious about it anyway.
  14. Sep 3, 2018 at 6:45 AM
    #174
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Bought a pre-runner blank dash piece and put the new ADD switch in place of the 4wd dial.
  15. Sep 3, 2018 at 6:47 AM
    #175
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Didn't even think of that. Nice work!
  16. Sep 3, 2018 at 7:19 AM
    #176
    6 gearT444E
    Deep South
    Herculiner Hootus
    Certainly
    RST does indeed sell a wiring harness "plug and play", I think around the tune of $100-150. You can make your own for the tune of around $30 and maybe 2 hours of your time, and also customize it to your liking. The ADD circuit is no different than any of the TRD differential lock circuits, so you can replace the ECU function with a DPDT switch.
    Front ADD circuit, you are dealing with the circuit in the top right of this diagram. There are a total of 6 wires that control the ADD, two for the motor, two for the limit switches which control when the motor stops in either direction (locked or unlocked) and one for a limit switch which is used to control your 4wd light on the dash. When you do the FJ swap you will now want the 4x4 dash light driven directly by the transfer case, so when you swap the FJ case in you cut and cap the wire going to the ECU from the 4x4 transfer case switch and tie it directly into the dash light circuit, this goes the same for the 4lo dash light. The limit switch on the ADD is now used as an indicator light on your new switch to tell you when the front ADD is engaged or disengaged.
    40624300_10117594366884614_3282952527229_c0cba0ab543520018478354c411d5d9b8cdd950b.jpg
    You take that circuit and deconstruct it and rewire it to a DPDT switch, the carling part number is at the top of this schematic I made showing how you will rewire the circuit. It is optional to add illumination to the switch, but certainly a nice feature. To do that, simply tie into the stock illumination circuit 12V and variable ground. You can use a momentary or maintained DPDT switch, whichever your preference.
    40685237_10117594367159064_4191734939542_b22632b8bae9b91f0b035e14a046484470052237.jpg
    Here you can see the switch pre-fabricated getting ready to wire it into my truck.
    40656474_10117594366964454_2046069119270_6aeabc1f16b42ec2c0fa3c7ab3c2fe2212e4dfca.jpg
    Another switch I've made up for @HomerTaco
    40823326_10117594367268844_6799217595057_147e40b62162a7887238866e6f0eef2c3b84da82.jpg
    Here is wiring into @HomerTaco's truck
    40609418_10117594366994394_7987905293793_ca82a35916d88c18fa51fd2409db287839954685.jpg
    Here's a test of the switch
    Another option instead of controlling it electronically is to leave it permanently engaged in the engaged position, or delete the ADD entirely. More details on that in this thread
    https://www.tacomaworld.com/threads/how-to-deleting-add-system.427258/
    You can put the ADD switch anywhere, but what most people have done is get rid of the 4wd stock switch and then buy the toyota pre-runner switch blank that goes there, and then put the new ADD switch in that switch blank.
    On a side note, I have an ADD switch and wiring setup I'm currently not using that I'd be willing to sell if someone does not feel comfortable making their own.
  17. Sep 3, 2018 at 7:29 AM
    #177
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Perfect. :cool:
  18. Sep 3, 2018 at 1:34 PM
    #178
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for posting 6 Gear T. I saved your diagrams for the future.
    I wouldn't call myself electrically challenged, at least compared to most, but it might take me a minute or two to wrap my brain around this DPDT thing. Perfect reading for a rainy afternoon holiday. Cheers!
    6 gearT444E and HomerTaco like this.
  19. Sep 4, 2018 at 6:47 AM
    #179
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    ADDs are overrated ;)
  20. Sep 4, 2018 at 7:20 PM
    #180
    tacomonster23
    06 Taco
    Finally started my FJ swap!
