Let's see your frugal DIY mods!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Nov 24, 2013.
  1. Sep 7, 2014 at 10:05 PM
    #221
    NosiBaLasi
    NosiBaLasi RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    Badge Black Out
    Smwlsh87 and B Wess08 like this.
  2. Sep 10, 2014 at 7:12 AM
    #222
    LUSETACO
    LUSETACO [OP] Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Used up some paint I had to paint my old cooler. It was looking pretty stained up from living in the bed of the truck. Also hit my tie downs and put those back on.
  3. Sep 18, 2014 at 9:50 AM
    #223
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Not much of a "mod" but frugal for sure. $1 from a yard sale and some leftover paint. A little extra storage for my winter stuff.
  4. Sep 18, 2014 at 6:13 PM
    #224
    Ripper
    Ripper Well-Known Member
    my one and only mod
    first version, and working on version 2.0
    Still getting use to using the hot wire cutter with furniture foam, 2.0 is using footer foam board leftover from job sites and will have a plastidip finish or a speaker box carpet lining. since 2.0 is scrap foam... it's free!!!
    Fastbilly5 likes this.
  5. Sep 18, 2014 at 6:20 PM
    #225
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Walmart had gripgo on clearance for $5 and i use my old phone to run torque so i can leave it plugged in all the time. $5 app and $12 adapter so $23 mounted scanning system ftw [​IMG]
    BrianT23 likes this.
  6. Sep 18, 2014 at 7:46 PM
    #226
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Welcome to TW Steve. Nice mod! :cool:
  7. Sep 18, 2014 at 8:52 PM
    #227
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    This project has taken quite a bit to finally complete. I used the DIY Hi-Lift and Tool Mounts write up to mount my shovel. Not the cheapest mod due the number of different pieces needed, and I bought extra for additional mounts. It was spread out over a couple months and felt thrifty. I am very happy with the result.
    erajytu8_b202f681525ec3c53f7b967effb6d81451ce371c.jpga9yma8em_3c14816522d5574e13d9dde5d4f7783a35b5b481.jpgrapebete_43e0f9364790304628209ec7b072a702bb5c8c5c.jpgryjasyva_7b075e3576b2384292a148da10b82836a54fc91d.jpg
  8. Sep 18, 2014 at 9:29 PM
    #228
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Might want to make some cutouts for your fingers to get in there & get it out.
  9. Sep 18, 2014 at 9:35 PM
    #229
    NosiBaLasi
    Jones
    How about a cut out for the magazine for safety? There's room for it :thumbsup:
  10. Sep 19, 2014 at 4:38 AM
    #230
    Ripper
    it is really soft cushion foam. No problem with rapid deployment of "Novelty Items"
  11. Sep 19, 2014 at 6:49 AM
    #231
    SilverJack
    SilverJack no one
    I love it when things are cheap and easy! I was going to use my flex stalk mount for my Nexus 7, but it fits perfectly above the cup holders. I have an Otterbox case which has a rubber surround. The case and rubber cupholders work to keep the whole thing from sliding around and the case base adjusts for perfect viewing angle. The Nexus has a built in GPS and I also use a BlueTooth OBDII reader. All the info is at my fingertips.
  12. Sep 19, 2014 at 7:07 AM
    #232
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I'd like more info on this app. What information does it give you. I just checked out their website and the info seems pretty limited (unless I missed it)
  13. Sep 19, 2014 at 7:31 AM
    #233
    SilverJack
    SilverJack no one
    I use torque as well on my Nexus. It has a bunch of info, but is dependent on your truck's ECU. For the Tacoma you can see coolant temp and intake air temps, but not oil temp or transmission temps. I can see A/F mixtures, get approximate MPG, O2 readings, RPM, Volts, vacuum, fuel flow. The Nexus will provide things like GPS speed, lateral G's and positional data.
    More info
    http://youtu.be/MV8VI8sY8r8?list=UUMgFGVSpiA8XFVD_WyhumFA
  14. Sep 19, 2014 at 7:32 AM
    #234
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    The app will read you everything that buying an ultra gauge will. But you have to buy the full app, but it's not very expensive
  15. Sep 19, 2014 at 7:32 AM
    #235
    yota243
    E.J.
    north Alabama
    i run coolant, tranny temp, engine load, instant mpg, intake temp, afr's, throttle pos, and fuel rate, but u can see voltage, cat temps, it will keep track of ur best 1/4's 1/8's 0-60 etc. it does just about everything a scangauge/ultragauge will do i guess. reads codes and can clear them. there are several features that dont work with our trucks but like the trans temp, there are addition PID's u can enter to get readings. there is a thread in the performance section about the app that is like 100 pages or so if u get bored. ha
  16. Sep 19, 2014 at 7:46 AM
    #236
    SilverJack
    SilverJack no one
    Oh man, I need tranny temps. Can you give me more info or links on the PID? I just scanned the available sensors, and didn't know I can add my own.
  17. Sep 19, 2014 at 7:53 AM
    #237
    yota243
    E.J.
    north Alabama
  18. Sep 19, 2014 at 7:55 AM
    #238
    SilverJack
    SilverJack no one
  19. Sep 20, 2014 at 1:12 AM
    #239
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    It will literally give you everything your ECU can provide. Its a great app. Something like $6 plus a cheap ODBII Bluetooth adapter.
  20. Sep 20, 2014 at 8:45 AM
    #240
    Ostrichsak
    Jer
    $4.95 to be exact. ;)
