Lets see your Satoshi Mesh and Mounting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDguyKC, Mar 14, 2010.
  1. Mar 14, 2010 at 12:36 AM
    TRDguyKC
    TRDguyKC [OP] Well-Known Member
    Kris
    Glendale, AZ
    Well, Im in the process of completing my Satoshi and Im not sure what mesh to use and how to mount it.
    That being said, id like to see what mesh you used, where you got it, and how you mounted it.
    thanks!
  2. Mar 14, 2010 at 6:49 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
  3. Mar 14, 2010 at 6:54 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Customcargrilles.com FTW!
  4. Mar 14, 2010 at 7:00 AM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    I need to do this over the summer!
  5. Mar 14, 2010 at 7:02 AM
    Lentsnh
    Get a grille to use because if you take your time and let everything set right. It'll take about 3-5 days.
  6. Mar 14, 2010 at 9:57 AM
    TRDguyKC
    Kris
    Glendale, AZ
    that looks really good. ill do a similar setup.
  7. Mar 14, 2010 at 10:00 AM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    How much are they about?
  8. Mar 14, 2010 at 11:48 AM
    NorthXNorthwest
    NorthXNorthwest Well-Known Member
    Myrtle Creek, Oregon
    07 Sport DC 4X4 Not Debaged
    BHLM, Ultra Mammoths, Husky mats, K&N non true CAI, window tint, Avid Steps and light bar.
    Nice!
    Ive been grill shoping and Ill be dammed if Im spending over 50 bucks for a chunk of grill for my Satoshi project.
    Custom car grills is abotu the cheapest I have seen for the DIY stuff.
    I have been looking high and low for a "honey comb" pattern. Well I found a company that had some...they wanted 149+ shipping arrrrrgh!
    IM hoping this thread will reveal some new sources and grill hole shapes...
    Oh giggety
  9. Mar 17, 2010 at 8:45 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Found honeycomb for 44+Shipping! and it is a 36" x 40" sheet!
  10. Mar 17, 2010 at 11:34 AM
    jonny
    jonny Betty White Edition Heep ZJ
    gotta be careful on the thickness though. some of the stuff i found online was pretty thin/flimsy.
    heres a shot of the perforated sheet i used. got it from Noe :thumbsup:
    excuse the dirty grill :laugh:
  11. Mar 17, 2010 at 11:40 AM
    Lentsnh
    Depends on where you buy it from. Craigslist, Toyota, or eBay.
  12. Mar 18, 2010 at 6:59 PM
    RSH904
    RSH904 Well-Known Member
    Akron, Oh
    Red and Black Attack
    Extang Trifecta Tonneau Painted Stock Wheels De Badged Yellow Fogs AVS Bugflector II UWS Running Boads Hunter Bully Bar HD Satoshi
    Still waiting for the final product back from the painter (my wifes uncle has a body shop). Here is what I sent to him.... L-brackets Epoxied in/ Fender washers due to wide holes in steel (I wont overheat = / ) and heavy guage stainless mesh sandblasted and red oxide primered. The entire unit will be black when I get it back.
  13. Mar 18, 2010 at 7:04 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    How did you attach those metal brackets?
  14. Mar 18, 2010 at 9:03 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    I should have taken pics of mine when I reworked it this last weekend. I used zipties across the top of the grille. Drilled holes about 1/2" in from the grille edge. That is my "failsafe" to hold it together in case the other mounting doesn't hold or breaks. You can't see the top of the grille unless you get down and look at it. So the black zipties I used are hardly noticeable. On the bottom and the sides I bought some machined bolts with nuts from the hardware store. They're small enough diameter to fit through my Grillcraft and they're about 5" long. I used a Dremel and cut the heads off so that the bolts could mount flat and straight on the grille. Then they stick out behind the grille. I painted some washers black to use to hold the grille on better. I used 4 of them on the bottom and then 1 on each side. I epoxied the hell out of each bolt to mount it to the plastic grille.
  15. Mar 18, 2010 at 9:25 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I used screw bosses (actually for nails) that are on a pipe hanger from Lowes (about 1.50 for 12 bosses) and mounted them using abs glue - pretty sweet untill I cut it all apart so that I can get to my winch.
    They look like this:
  16. Mar 19, 2010 at 5:26 AM
    RSH904
    Akron, Oh
    Gorilla Epoxy/
