Lets see your tool boxes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Oct 5, 2008.
  1. Oct 5, 2008 at 11:03 AM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I need a place to store all my stuff (air compressor, jumper cables, tow strap ect.) and have decided I need a toolbox. Using my backseats is no longer cutting it because I need to be able to move people if need be.
    I'm leaning towards a UWS box because of their reputation. I only really want a low profile box in black. Not a fan of the chrome and I don't want to cut down on my rear visability.
    Lets see some toolboxes!
  2. Oct 5, 2008 at 11:16 AM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    Im thinking about doing the same... black low profile. (superwhite)
  3. Oct 5, 2008 at 11:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    here is mine.....uws black low profile......
    i need to get some better pics of it:eek:...didnt realize these were that shitty!!:D
  4. Oct 5, 2008 at 11:22 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i havea UWS in black...not low profile tho
    ive had mine about 3 months less than ive had the truck (roughly 3 years)
    the powdercoat on it has peeled and cracked etc to the point i just went to the car wash to pressure wash it off...my lid is currently half black and half shiny...i'll eventually finish it off and recoat it with something else
    as far as the box itself is concerned...its great...i keep all kinds of crap in there and it has a sliding tray in it for small stuff
    my passenger side lift strut has come unattached at the box...still attached to the lid...and i still have no issues opening or closing it...
    ive stood on mine...thrown stuff on it and in it...ripped it off the bed via a tree...and ive had no issues other than the strut and powdercoat coming off
    i have my cb antenna and my hilift mounted to it and theyre holding strong as well
  5. Oct 5, 2008 at 11:28 AM
    JimBeam
    JB
    2015 Tundra
    this is what mine looked like in February
  6. Oct 5, 2008 at 11:46 AM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    I went a slightly different route. I rarely need to transport long or really big stuff (compressor, shovels) locked up. I decided to make something that would fill my needs water tight, sturdy, not take up too much room, easy to remove when needed. I took two large ammo cans and using bolts with wing nuts attached them to the bed rails. I've since installed locks and a bike fork mount, sealed the holes and weatherstripped the lid. I need to take pictures. I'll eventually paint them but the brown military look has grown on me, and their current appearance makes them less tempting to thieves. They have built in handles which have come in very handy and thanks to my use of clear silicone and weatherstripping are weather proof, even up to a pressure washer. The gap between them is great for long items like tables or plywood. And the gap is just right to fit a 5 gallon gas can. I paid under $20 for 4 cans and the hardware to mount two. I might setup the other two later on to mount on the sides if I need more room, doubtful.sideview_144974c6e3c5b6e9db47785f13269a51b7c71f39.jpgopenlid_3a850884017f1fa707355df832cecae549d2df0c.jpgboxes_5aa03b8a8fac8a08cf54eec658190533cc75135a.jpg
  7. Oct 5, 2008 at 11:50 AM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    That looks great. How did you mount them?
  8. Oct 5, 2008 at 11:52 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i really like this idea. looks pretty damn good man. if i had them, i'd probably use bed liner material on them, but thats just me.:)
  9. Oct 5, 2008 at 11:58 AM
    lawnrevenge
    Southern California
    With wing nuts and bolts in the rails. In the second photo you can see them, I think they are 3/8" or 1/2". The trick is to use square washers and tack (or even glue) the bolt heads to the washers so they don't spin. The photos are from test fitting them. For now I just used silicone on the bolt holes to seal them but when I take them out for paint I will make some rubber gaskets, I trimmed down the bolts. I was worried about flex but these are solid, they originally help 3 81mm cartridges, 57 lbs. Capacity for each is just a little more than 2 12 packs of coke.
  10. Oct 5, 2008 at 11:59 AM
    zombot
    zombot Scavenger
    savannah
    08 white debadged panda
    bull bar and offroad lights, tool box and other minor storage mods
    those ammo cans are brilliant! i like the look. plus in my case there's still room for a bike's tire to fit in between ....and talk about low profile!
    if i get an ol' beat up apocalypse truck , i'll remember that trick.
    with your newer ride, i bet those would look bad-ass with some bedliner on them!
    as it is, i still think the sheer ingenuity makes up for whatever clash they have up against a new truck.
  11. Oct 5, 2008 at 12:01 PM
    lawnrevenge
    Southern California
    Thanks. I am leaning toward the bed liner. Was thinking to paint them silver but after Phantom's experience I think black will be good. The boxes are galvanized so when I paint them I'm going to do a lot of prep work, otherwise the paint will flake off (like the original brown has done in a few places.
    Forgot to mention...I hate painting. Painted my old VW bug and that started me down the path of not ever wanting to paint...
  12. Oct 5, 2008 at 12:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i think the bedliner will be very durable.....more so than paint too, plus the prep work for using the liner material isnt too bad.:)
  13. Oct 5, 2008 at 12:07 PM
    lawnrevenge
    Southern California
    If I were to paint these I'd completely strip them, use etching primer since they're galvanized, and then give them 3+ coats of black enamel, no clear coat so touch-up would be easy. If I go with bedliner paint I'll still need to strip it to metal, maybe I can bypass the primer, depends on what the manufacturer says. When I get around to it I'll post pics. Might wait until summer, painting indoors isn't fun.
  14. Oct 5, 2008 at 12:57 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    There is your solution if your cheap, like me. Also if you hate the thought of permanently giving up your bed length, like me. :D
  15. Oct 5, 2008 at 1:40 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yeah, i did the same sort of thing. i went down to wally world and picked up a box for about 50bucks if i remeber right. it fits all kinds of crap and i can easily pull it out if i want to. i'll try to get a pic and throw it on here later.
  16. Oct 5, 2008 at 2:14 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    I know it cost $450 bucks but you will not find a better box than the Toyota one. The best part is you can buy parts for it at your local dealer. I lined mine with carpet and I love it.
  17. Oct 5, 2008 at 3:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Here is mine. Husky from Home Depot:
  18. Jan 9, 2010 at 10:46 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    heres my custom setup
  19. Jan 12, 2010 at 2:04 PM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    The ammo boxes affixed to the bed rails is geneous! +10 for that guy!
  20. Jan 13, 2010 at 7:17 AM
    magneticnick
    Nick
    Orange, CA
    None Yet
    thanks:D
