Level 8 Mk6 wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by 07toyota1991, Feb 28, 2017.
  1. Feb 28, 2017 at 7:24 AM
    07toyota1991
    07toyota1991 [OP] Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    Howdy all!
    I found a killer deal on some 16x8 Level 8 wheels with new BFG's on Craigslist. I am trying to make sure these will fit my 99 Tacoma with manual lock out hubs...? Any ideas?
  2. Feb 28, 2017 at 8:10 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    got a link? or got specs?
    any Toyota 6-bolt will fit. backspace becomes an issue unless they are stock size tires.
  3. Feb 28, 2017 at 8:11 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Ask @Discount Tire Direct
  4. Feb 28, 2017 at 8:12 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    ^ This. We need to know the specs on the wheel before we can say yes or no on fitment.
  5. Feb 28, 2017 at 8:15 AM
    07toyota1991
    Wheels are 16x8 6x5.5 bolt pattern offset is -10 back spacing is 4.5 i believe.
    Tires are 265/70/16 BFG A/T KO2
  6. Feb 28, 2017 at 8:20 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    -10 offset doesn't match 4.5" BS. However 6x5.5 is correct, 16" x 8" will fit, -10mm offset (~4.10" BS) will fit, 4.5" BS (0mm offset) will also fit. Looks good :thumbsup:
  7. Feb 28, 2017 at 8:24 AM
    07toyota1991
    4.10 BS is what I meant! Typo on my behalf
  8. Feb 28, 2017 at 8:26 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    All good, that'll fit.
  9. Feb 28, 2017 at 8:27 AM
    07toyota1991
    all all centers the same size? I want to make sure my lock out will fit through
  10. Feb 28, 2017 at 8:45 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    From what I've read the hub size is the same for all 1st gen 6 lug Tacomas (manual locking hubs or ADD)
    07toyota1991[OP] likes this.
  11. Feb 28, 2017 at 8:50 AM
    07toyota1991
    Thanks all for the help! Sad that I am getting rid of my FJ Trail Edition TRD wheels but the deal is worth it!
  12. Feb 28, 2017 at 9:34 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I believe all the Level 8 are hub centric wheels, which are optimal.... they'll clear the hubs and lockouts for sure. -10 will stick out a bit, but will look nice IMO
  13. Feb 28, 2017 at 9:40 AM
    07toyota1991
    I have close to 2" of lift on my rig. The -10 shouldn't be enough to rub will it?
  14. Feb 28, 2017 at 9:43 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    with stock size (265/70) tires you should be fine
