Leveling a 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ronjonsilvers, Nov 17, 2015.
  1. Nov 20, 2015 at 8:16 AM
    #61
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    there hasnt been any reported driveline vibration caused from lift yet. most are running without shims or cb drop also so youll be good.
  2. Nov 20, 2015 at 10:25 AM
    #62
    Trump16
    Trump16 Active Member
    Wallace
    Cool. How high do you think you can go without problems?
  3. Nov 20, 2015 at 10:28 AM
    #63
    pngo121
    Phi
    Pittsburg, CA
    mostly everyone is doing 1.5" in the rear. not sure how much higher you want.
  4. Nov 23, 2015 at 9:29 AM
    #64
    ronjonsilvers
    ronjonsilvers [OP] Well-Known Member
    California
    2017 Tacoma TRD Sport 4x4 White
    Window tint, Go-rhino nerf bars, 32 inch Caliraised LED light bar, LED conversion, Caliraised amber LED fogs, Billstein 5100’s at 1.1 inch lift, Empyre off-road grill, Tacoma tailgate inserts, black TRD 4Runner rims/Falken ATs, ASV window visors and pedal commander programmer
    Being that the 3rd gens come 1 inch higher in the front stock. If I added my billsteins at 1.5(or whatever the 3rd notch is) would that put the equivalent stress of 2.5 inches of front lift??? Versus just doing the .85 adjustment.
  5. Nov 24, 2015 at 2:59 PM
    #65
    ronjonsilvers
    California
    Finished product ladies and gentlemen! Thanks to all for everyone's input.
    -Billstein 5100's at .85 (2nd notch)
    -Mickey Thompson Baja Lock 17
    -BFG rugged terrains 265/70R17
    nctrd17, Para8291 and Airborne daddy like this.
  6. Nov 24, 2015 at 3:05 PM
    #66
    Airborne daddy
    Airborne daddy Well-Known Member
    Jamie
    knoxville, tn
    2016 Trd sport
    So, nothing on the rear? Just the Bilsteins at 2nd notch on front and that happened?
  7. Nov 24, 2015 at 3:10 PM
    #67
    ronjonsilvers
    California
    Exactly that
  8. Nov 24, 2015 at 3:15 PM
    #68
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    That's what I will do next year when the tires are shot. I don't want to get all crazy with lifting my truck. Just give it a little Batta Bing! That looks great.
    ronjonsilvers[OP] likes this.
  9. Nov 24, 2015 at 3:42 PM
    #69
    ronjonsilvers
    California
    That's exactly what I was going for, not to spend a ton of money lifting it and wearig out the components (ball joints, exc) but give it alittle pop and turn a head or two :)
  10. Nov 24, 2015 at 9:57 PM
    #70
    Lcsaychao
    Lcsaychao Member
    Do you still need to do an alignment after .85 lift?
  11. Nov 24, 2015 at 10:22 PM
    #71
    ronjonsilvers
    California
    I marked my alignment cams so when I bolted everything back up my steering was straight as an arrow..... Only down side is my wheels had a slight slant to them so it is a good idea to get an alignment after. You can see the front tires kind cock eyed in this picture, the top leaning out
  12. Nov 24, 2015 at 11:30 PM
    #72
    Lcsaychao
    Lcsaychao Member
    @ronjonsilvers - Thanks, maybe I'll have to jump on the deal at Jet.com
  13. Nov 25, 2015 at 1:22 AM
    #73
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    you should after any kind of lift - why take a chance on trashing those expensive new tires.
  14. Nov 25, 2015 at 4:44 AM
    #74
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    you may want to get your camera aligned as well, lol.
    remgu2000, titian36 and aweddle14 like this.
  15. Nov 25, 2015 at 5:33 AM
    #75
    border411
    border411 Well-Known Member
    Had anyone actually done measurements with the stock suspension to see how much higher the rear is than the front on level ground?
  16. Nov 25, 2015 at 5:50 AM
    #76
    Markc1024
    Markc1024 Well-Known Member
  17. Nov 25, 2015 at 8:21 AM
    #77
    border411
  18. Nov 25, 2015 at 8:33 AM
    #78
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Your truck looks good man, was actually thinking about doing this to my 2016 SR Access Cab. Getting 4 Billsteins and setting them at 2.5 in the front and using my stock coils and and all you have to do is add a AAL or 1.5" block to level it out? I can get all 4 Blisteins on www.jet.com for like $306.92 shipped! And they are doing 20% off your order too now! So with a 2.5" front lift will the alignment be ok or do i have to do UCA?
    Rear Shocks: https://jet.com/search?term=24-186728
    $106.24 each
    Front Struts: https://jet.com/search?term=24-239370
    $85.59
    aweddle14 likes this.
  19. Nov 25, 2015 at 1:37 PM
    #79
    Para8291
    Para8291 Well-Known Member
    Rob
    San Antonio
    2016 Tacoma TRD Sport
    Bilstein 5100s all around, Toyo All Terrain AT II 285/70/17, Custom Car Grill, front windows tinted at 35%, door still protectors, bed Matt, tail gate lettering, center console organizer and detailed with Adam's Polishes products
    moe2o4 likes this.
  20. Nov 25, 2015 at 3:36 PM
    #80
    Sir Taco
    Sir Taco Well-Known Member
    2016 TRD sport 4x2
    What size tires you running
