Leveling blocks causing axle wrap? WITH VIDS
Discussion in '1st Gen. Tacomas (1995-2004)' started by WildLand, Jan 14, 2014.
  1. Jan 14, 2014 at 3:13 PM
    WildLand
    WildLand [OP] Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    howdy
    So I've had a clunking noise in my truck and was told that it might be from axle warp where the leaf springs are warn down and old.
    Could this be from the 3 inch leveling block that is on top of my leafs or is it just old leaf springs? I know many of you have replaced your leaf springs but wasn't sure if it was for the lift or if the leaf springs just get old (especially mine being 14 years old).
    Thanks in advance!
  2. Jan 14, 2014 at 3:15 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    idk how the clunking noise could be from your leaf springs being worn down.. but anyways
    the leveling block will make your leafs frown faster
    they will make axle wrap worse because it gives the axle more leverage on the springs
  3. Jan 14, 2014 at 3:26 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    oh just because of separating upon accelerating. Just what a member said it might be.
    So take out the blocks or get new leafs that raise the back 3 inches instead?
  4. Jan 14, 2014 at 3:31 PM
    4runnercaged
    cody
    arizona
    LOL
    i see what your saying, the axle wrap will cause seperation then it going back together could be a clunk.......
    yes you can do that. you dont need a whole new leaf pack to gain 3 inches. you can use a add a leaf, and you can find them tons of places like wheelers, ome, icon
  5. Jan 14, 2014 at 8:29 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    You might want to see how much damage the block has caused first.
    Removing the block and replacing with a add a leaf might just be a temp fix if the rear leafs are frowning.
    And might get you by for a while but... in the end might need new leafs ...
  6. Jan 14, 2014 at 8:37 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    I'll check the damage of the blocks and if they aren't frowning then should I add a leaf for the lift to match the front? I've only had the blocks for 7 months so I don't think they could make the frown that fast.
    But adding a leaf should be okay since I plan on keeping the truck for only a couple more years, right?
  7. Jan 14, 2014 at 8:47 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Should be fine as long as the leafs arn't toast.
  8. Jan 14, 2014 at 8:49 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    sweet thanks! :cheers:
  9. Jan 14, 2014 at 8:51 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  10. Jan 14, 2014 at 9:05 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks man, I was wondering what other truck leafs I could use (don't know suspension at all) but I'm always up for a project and wanting to learn!
  11. Jan 14, 2014 at 11:33 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Deaver J59 leaf packs are pretty good and strong... i ran those for years before rebuilding my truck....
  12. Jan 15, 2014 at 7:40 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    there are multiple threads on here about this. after coming to a stop, your rear leafs bind up, then as you drive again you get the clunk as the tension (wrap) releases?
    I fixed it by clamping a universal ubolt on the front side of the leafs. autozone has them.
    If that doesnt work, then yeah your block could be contributing to the problem but more than likely its just the springs.
  13. Jan 15, 2014 at 4:40 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    I would if I had the money at the moment. You know suspension I can tell haha
    That's the route I was gonna do. Just buy some ubolts and tighten them on. I just was wondering if it that could happen with or without the blocks and now know that the blocks arent causing it if it is the warping. Do you just have one u bolt on each side
  14. Jan 15, 2014 at 5:58 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    ive heard people say that blocks mess up springs prematurely. i dont see how. the leafs are touching the same surface area whether its the block or on the axle perch.
  15. Jan 15, 2014 at 6:40 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I agree, I ran 2.5" blocks on my rockcrawler for 15 years. Didn't seem to cause additional 'frowning' . I did have one cracked leaf after about 10 years. Easy fix.
  16. Jan 15, 2014 at 7:00 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thats what I thought too. Maybe more pressure somehow? I don't know, people just made me nervous that my blocks are damaging my leafs
    Well thats reassuring about the 15 years part! I'll just keep them and u bolt the leafs to stop them from clunking
  17. Feb 21, 2014 at 4:04 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Took some gopro footage of my truck to see what the clunk is in the back. Can you guys tell if this is axle wrap? you can here the noise at :17 and :28 on the first video. Also you can see the axle move or is that normal?
    and also can you tell on this video? this one probably isnt helpful
  18. Feb 21, 2014 at 4:18 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    Even after going with a new leaf pack I still had axle wrap. What cured it for me was tightening the u-bolts down to 90 ft/lbs.
  19. Feb 21, 2014 at 4:22 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Do you think that getting new struts for the back would help keep the axle in place?
  20. Feb 21, 2014 at 4:38 PM
    wrat
    Wyoming
    No. The blocks are definately not helping. Get a torque wrench and tighten all of your u-bolts to ~80 ft/lbs and then take it for a drive. See if that cures the issue.
