Leveling Driver Side
Discussion in 'Suspension' started by testedone, Nov 2, 2009.
  1. Nov 2, 2009 at 1:26 PM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    2010 DC
    Toytec Coil Overs
    Right now they are set the same. I plan to go to the alignment shop in the morn so want to do this right once...
    If I raise the driver Coil Over by 1/4 inch that equates to 1/2 inch of lift...correct?
    Is this all I should do to level the driver side. I know I can measure and will but deciding when to measure (1/2 tank of gas, full tank, empty..etc.) gets a little "out there"
    What do you all think is the best way..
    Thanks
  2. Nov 2, 2009 at 1:52 PM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    hard to say. i ended up calling toytec and asking them for assistance. the best advice i can give you is to do it on the truck with it jacked up on stands and the tire removed.
    i tried doing it myself with no luck at first. even bent the wrench. called toytec and the guy laughed and said spray the threads with Wd40 and let it sit for about 30 min.
    went back out there and sure enough i was able to easily crank away. i ended up playing around with it a few times. about 1/4 inch i would say.
    let it settle for a while like this before getting alignment. make sure you have it where you want it.
  3. Nov 2, 2009 at 2:19 PM
    testedone
    Rick
    U.S.A.
    my question is not along the lines of how..but how much?
  4. Nov 2, 2009 at 2:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Every 1/4" adjustment, translates to 1/2" at the tire.
  5. Nov 2, 2009 at 2:26 PM
    testedone
    Rick
    U.S.A.
    Thanks, just wanted to be sure, I am going to raise it 1/4 (= 1/2) then measure from bottom of fender well to center of wheel hub or from cab to ground?
  6. Nov 2, 2009 at 2:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Fender to center of hub should be more accurate. Adjust it, then go for a quick drive, then check it.
  7. Nov 2, 2009 at 2:30 PM
    testedone
    Rick
    U.S.A.
    Tanks :cheers:
  8. Nov 2, 2009 at 2:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Nov 2, 2009 at 2:48 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    How the hell do people get this lean thing?
    I did the lift on mine with the 5100 and there were no problems of a lean...
  10. Nov 2, 2009 at 2:51 PM
    trailmaster308
    Louisiana
    ya i realize that. just offering the easiest way i found to do that. reason being is that it took me three tries before i got it just right.
  11. Nov 2, 2009 at 2:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OEM springs have a heavier rate on the driver side. Other springs dont. Therefore, a lean can happen.
  12. Nov 2, 2009 at 3:49 PM
    Masada
    Taylor
    Laveen, AZ
    I got you, so are the OEM springs stiffer on the driver side to compensate for the driver?
  13. Nov 2, 2009 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A little bit. To compensate for the fuel tank, battery, and other heavy things on that side.
  14. Nov 2, 2009 at 4:14 PM
    Masada
    Taylor
    Laveen, AZ
    I see, so what would one do to compensate for the same things when moving to aftermarket springs? Add a spacer or shim to the driver side.
  15. Nov 2, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct.
  16. Nov 2, 2009 at 4:20 PM
    Masada
    Taylor
    Laveen, AZ
    See I'm learning...:D
  17. Nov 2, 2009 at 4:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Nov 2, 2009 at 5:16 PM
    testedone
    Rick
    U.S.A.
    understood, I am on my third try also.. :)
    Well I got it done, the thing I did not do before was drive it after adjustment...
    So I did that three times tonight, the driver side is 1/8 higher then the passenger and I have less then a 1/4 tank so I left it at that.. I had crank this up about 1/2 inch to achieve this (1/2 = 1 inch lift)
    The funny thing is it still looks like it has a small lean from the rear which I would suspect is because the rear springs are also leaning...but no way to compensate for that... :(
    But it's done and I get it aligned tomorrow..
