Leveling Kit on 2017 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dat_Taco_Truck, Sep 27, 2018.
  1. Sep 27, 2018 at 6:04 AM
    Dat_Taco_Truck
    Dat_Taco_Truck [OP] Member
    Colton
    2013 White Toyota Tacoma
    3/4 Suspension Kit & Magnaflow Muffler
    so I have a situation, I have different opinions all over this forum. I just got. A 2017 SR5 with 14k Miles. The suspension I love but I want to level the front probably 2 inches. Now i don’t know if I should go all in for a whole front kit or Coil spacers which I hear great things about and also not great things about. My friend told me that the spacers are just a cheap way of leveling my truck but I wanna know what experienced 3rd gen Taco owners say THANK YOU!!!
  2. Sep 27, 2018 at 6:19 AM
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    If you’re not off-roading and lifting for aesthetics, go with spacers.
    Dat_Taco_Truck[OP] and kgilly like this.
  3. Sep 27, 2018 at 6:49 AM
    Puddle_Jumper
    Puddle_Jumper Well-Known Member
    Bruce County Ontario Canada
    2017' Tacoma TRD Off-road DCSB
    Bilstien 2/1 level kit with 5100’s front (top setting) and 5160’s in the rear Ecgs bushing Prinsu cab rack Bestop Cali raised ditch lights Rago fab bed stiffeners Rssw heritage wheels with 32” ko2’s Westin bed mat Pro grille and tail lights Led dome, map and licence plate lights
    What he said ^
    kgilly likes this.
  4. Sep 27, 2018 at 10:06 AM
    Dat_Taco_Truck
    Colton
    Alright, thank you. I’m planning too off-road it at least a couple times a year but I work full time so It won’t be more than 5 times at least
  5. Sep 27, 2018 at 3:31 PM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    2" in the front you may want to look into a 1.0" spacer in the rear as well. I did a lift in the front and ended up with this "bro-lean" thing where my truck was now squatting to the rear a bit. That look drove me nuts personally. I got a set of 1.5" spacer blocks put in the rear and that got things back to more of the stance i was looking for. You can see the Bro lean on the first pictures and the result after on the second page.
    As a side note I tow and carry gear for work with me often. So got a set of 610 Sumo springs put in as well. The ride is stiffer but it doesnt squat when i have a load in the bed or towing nearly as much at all. https://www.amazon.com/dp/B00O4GD38M
    heres the thread i had on this very subject a number of months ago https://www.tacomaworld.com/threads/should-i-bump-the-rear-up.541219/
