Leveling kit or lift kit
Discussion in 'Suspension' started by Slipknot4x4, Dec 5, 2017.
  1. Dec 5, 2017 at 10:24 PM
    Slipknot4x4
    Slipknot4x4 [OP] New Member
    2013 TRD off road double cab 4 x 4
    I have a 2013 TRD off road double cab I was told that I didn't want to use a leveling kit because the off roads suspension is already maxed out ball joints ect..is this true because I would like to lift my truck at least 3 inches with the most cost effective method!
  2. Dec 5, 2017 at 10:30 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Not true.
    However I believe 2.75 is the max lift on a 2nd gen and you're going to need a cab mount chop running bigger tires.
    It also not recommended to run a 3 in lift on factory upper control arms. Tons of lifted 2nd gens in here.
  3. Dec 5, 2017 at 10:32 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    BassAckwards and Matic like this.
  4. Dec 5, 2017 at 10:37 PM
    Matic
    Tricky Dick
    Easley, SC
    My bad. Welcome to TW.
  5. Dec 5, 2017 at 11:44 PM
    Slipknot4x4
    So it is sorta true that the ball joints and such are maxed out with the addition of a leveling kit or coilover adjustable kit! So an actual suspension lift kit would be the way to go?
  6. Dec 6, 2017 at 4:57 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  7. Dec 6, 2017 at 6:41 AM
    BassAckwards
    AWD Turbo 2TR-FE
    Welcome aboard! :D
  8. Dec 6, 2017 at 6:43 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What purpose will the lift be serving? Functional or mall-crawler?
