leveling kit problem
Discussion in 'Suspension' started by beacher, Dec 19, 2010.
  1. Dec 19, 2010 at 1:55 PM
    beacher
    beacher [OP] Well-Known Member
    09 TACOMA 4x4
    2" spacer lift in front end bf goodrich allterrain tires custom exhaust system tinted windows smelly interior
    hi, i was wondering if anyone could help me out . a couple weeks ago i installed a 2'' leveling kit on my 09 Tacoma , but i didnt install a differential drop kit and the vehicle is riding kind of weird. its a lot different. will i screw up the front end or cv joints if i dont put a diff drop kit in? theres a vibration sometimes that wasnt there before, but its hard to notice.thanks for reading.( already got wheel alignment done)..
  2. Dec 19, 2010 at 3:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What kind of leveling kit is it? Coil spacer or top plate spacer?
    First thing to check is to make sure everything is still torqued down and that nothing has shifted.
    Someone else will chime in about diff drops but they are basically worthless.
  3. Dec 19, 2010 at 3:11 PM
    beacher
    09 TACOMA 4x4
    it mounts on the top of the struts
  4. Dec 19, 2010 at 3:26 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I did a Readylift 2.25" leveling kit and brought the front up with a diff spacer kit included in the box. No vibrations or problems at all at any speed. In fact I had to add a 1" spacer block to the rear leaf spring because the rear was low after. Readylift said no need to change shocks. 2010 TRD Sport. I am not sure why the diff spacer kit is useless. I don't know much about it but it seems logical to me to lesson the cv joint angle if thats what it does.
  5. Dec 21, 2010 at 6:32 AM
    beacher
    09 TACOMA 4x4
    so i should probably get the diff drop..? thanks man
  6. Dec 21, 2010 at 6:37 AM
    KPT
    09 Prerunner
  7. Dec 21, 2010 at 6:52 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Diff. drop is debatable. I don't think a 2" lift would be too drastic for a diff. drop kit but kit is pretty cheap if you have concerns. It may/may not fix your issues. I usually get my tires balanced at the same time of alignment and get a copy of your alignment printout to see if the specs are acceptable for a lifted truck.(there are many alignment postings here)
  8. Dec 21, 2010 at 8:45 AM
    beacher
    09 TACOMA 4x4
    yeah , i got the alignment. but maybe its off since it is higher now. also i havent noticed any unusual tire wear so it could be right.
  9. Dec 21, 2010 at 8:47 AM
    beacher
    09 TACOMA 4x4
    now that i looked at that link KPT posted i changed my mind about getting the diff drop kit haha.. damn thats ugly, if that happened to me , i would probably shit my jeans, and throw up at the same time..
  10. Dec 21, 2010 at 12:09 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I say make sure you have a good alignment...and by good I mean not just within the "specs" as they are a very wide area.
