Leveling Kit Questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Navar, Jan 31, 2014.
  1. Jan 31, 2014 at 10:15 PM
    Navar
    Navar [OP] Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    All right forgive me if I posted this in the wrong place.
    I have a 07 Tacoma 4x4 and I am looking at doing the Bilstein leveling kit. I just want to give it the level stance. I am also adding the Method 301 wheels in as well.
    My question is how will this effect ride quality? I am not looking to push them all the way or add any blocks or leafs in the rear.
    2nd question is can what I am going to do damage anything?
    Is it better to add coils with these shocks or should I be ok with stock coils?
    Thanks everyone.
  2. Jan 31, 2014 at 10:21 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    What exact kit are you looking at?
    Overall, if you're just leveling, you shouldn't have any issues with ride quality and/or damaging anything.
  3. Feb 1, 2014 at 12:18 AM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    The stock coils will be fine. I run the stock coils with my bilsteins.
  4. Feb 1, 2014 at 9:15 AM
    Navar
    Corona CA
    I'm going with the Bilstein 5100's.
    Like I said at this point just want to level it. I really don't go off road much. I would like to start exploring just not into the rock crawling and hardcore stuff.
    Seems like a lot of builds on here go with a spring as well then to level the rear add a leaf. Making it all most a 3' lift? Also adding a UCA as well.
  5. Feb 7, 2014 at 10:13 AM
    Navar
    Corona CA
    Looks like I can get Kings non resi cheaper than Icon non resi extended travel. about $150 cheaper
  6. Feb 7, 2014 at 12:04 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If your still just leveling it out all should need are the 5100's set at 1.75" depending on your truck. I originally set mine at 1.75" with no rear extras. It sat pretty level, but depending on how you looked at it sometimes it looked nose high on one side. So I just put a 1" block in the rear. I've had AALs before and I don't like how they ride. Don't do any extreme off roading. Everything rides great.
  7. Feb 7, 2014 at 4:08 PM
    Navar
    Corona CA
    After a lot of the reading on here I am backed off the 5100's. I want something better for when I do go off road. Really just torn. right now. been looking at a few different options
