Leveling kit vibration
Discussion in 'Suspension' started by Jeremy2046, Dec 25, 2018.
  1. Jan 26, 2019 at 8:15 AM
    phoenixpiole
    phoenixpiole Well-Known Member
    2018 Tacoma DCSB SR5
    We’re you able to get the TT3DS shims installed without modification to the Dakar springs?
  2. Jan 26, 2019 at 8:57 AM
    My White Tacoma
    My White Tacoma Well-Known Member
    Andrew
    Springfield, mo
    2014 White Tacoma double cab, SR5, 4x4
    I haven't got them yet. I ordered them the other day. They should be here Monday. But I wont be able to install them until I get back from vacation. I'll let you know once I do get them installed. But it'll be a couple weeks.
  3. Jan 26, 2019 at 9:44 AM
    phoenixpiole
    Alright sounds good keep us posted, I think I’m going to try these too.
  4. Jan 30, 2019 at 2:03 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    I bought my 2012 with a 3 inch level kit and it vibrated like an adult pleasuring toy.
    Took it off and installed Fox's and the taco drives like a dream :burnrubber:
    Jeremy2046[OP] likes this.
  5. Jan 30, 2019 at 3:06 PM
    Jeremy2046
    Jeremy2046 [OP] Member
    Jeremy
    18 tacoma sport
    None
    While my girl might actually enjoy that I’d like to resolve issue with the kit installed. I found I have a 1.5 degree difference between the rear pinion input shaft and the transfer case output. Not sure if this is enough to cause the vibration. It’s really not that bad but being a new truck I feel like it should be damn near perfect. First new vehicle I’ve ever had.
  6. Feb 4, 2019 at 7:41 PM
    My White Tacoma
    Andrew
    Springfield, mo
    I had some time today to install these shims. They installed just like I figured. Remove the old bolt, install the new bolt through the shim, keeping the circle grove on bottom and the wide point of the shim to the back of the truck. You may have to cut the top of the bolt off to install the bumper over it. I didn't have to because I installed an u-bolt flip kit and new aftermarket bumpers. I don't know why on Toytec web site it says requires drilling. I have the new style, Part # EL096R. Maybe the old ones use a smaller bolt? I don't know.
    I do have a concern though. Because the shims rotate the axle back, it drops the welded eye for the shock in the back downwards and the one on the front of the axle upwards. I had to jack the axle up and force my rear shock into it's place. It is in there tight and I hope it does not fail prematurely.
    Did it fix it? .....Yes and no. It helped a lot, but it's not gone, but I can live with it. Under normal acceleration it's not noticeable, but heavy acceleration or starting up hill you still feel it from 0-20 MPH.
    @phoenixpiole
  7. Mar 5, 2019 at 4:41 PM
    My White Tacoma
    Andrew
    Springfield, mo
    Update: I still had vibration that I was not happy living with. So I did the front needle bearing swap and it took care of just about every vibration that I was getting. It eliminated more vibration then the axle shims did. I thought the vibration that I was feeling was driveline vibration, but it turned out it was from that bearing. Grab your driver side axle up by the diff and move it around. I bet this is the OP's problem.
    veggtaco likes this.
  8. Oct 21, 2021 at 11:36 AM
    dipaolo454
    dipaolo454 New Member
    2013 tacoma Limited black
    I just did the Rough Country 2.5 leveling kit. Great ride -- and great look BUT....(and if your not doing work yourself) -- get ready for 300 to install and you will probably need the center bearing lowering kit 25 bucks or so AND you will probably need the needle-bearing replacement 250 with the install tool and new gasket (250 - 300 or more to install) on the drivers side because the truck will make a hum...AND did I mention the 125 wheel alignment SO yeah you have to be willing to pay much more (over a grand all-in) for the look you want then just the price of the new struts. They don't tell you all this -- they just sell you the kit; but hey, it is what it is. THE new bearing WILL eliminate the noise!
