Leveling Kit
Discussion in 'Suspension' started by hodgerussell, Aug 21, 2012.
  1. Aug 21, 2012 at 6:08 AM
    hodgerussell
    hodgerussell [OP] Member
    Russell
    Edmonds, WA
    05 Double Cab, PreRunner, K&N Cold Air Intake
    K&N Cold Air Intake, Hellwig Rear Helper Springs, Bilstin 5100 Adjustable, 31" Toyo A/T's
    I'm trying to figure out what size leveling kit I should get for my 05 double cab prerunner. I put a load support in the rear and it ended up raising the back end a few inch's. I'm trying to get the same look in the front but don't want to spend the thousands for a lift kit. I've see people post that they did 1" in the rear and 2.25" in the front. I'm just trying to get the best height to make it level. Thank you for all your help
  2. Aug 21, 2012 at 6:13 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    5100's either at the middle setting or top. It's adjustable so just get those as see where you need to set them at to match the rear.
  3. Aug 29, 2012 at 6:34 PM
    hodgerussell
    Russell
    Edmonds, WA
    Thank you. I looked at these and thought they were awesome so I just ordered them yesterday and they should be ready for pick up Friday. Thanks again for your help
