Leveling kit....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mose1117, Oct 13, 2021.
  1. Oct 13, 2021 at 12:07 PM
    mose1117
    mose1117 [OP] Well-Known Member
    Sacramento,CA
    2015 DCSB TRD SPORT
    Amazon.com: 3"F + 2"R Leveling Lift Kit for Tacoma, 3" Front Strut Spacers and 2" Rear Black Leveling Lift Block Kit Extended Square U-Bolts, 3"+2" Height for 2005-2019 Tacoma 2WD/4WD : Automotive
    Looking at this one for my 2015 Tacoma DCSB. Seen posts about CV boots ripping and all kinds f things that "need" to be changed when doing a leveling kit like this. Could anyone chime in with thoughts? My plan is for TRD Pro rims with something like 265/70/17's...Thanks!!
  2. Oct 13, 2021 at 12:23 PM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    just say NO to spacer's in the front. Instead, save a little more coin and get 5100's or a complete 2.0 Fox kit. If you stay under 3" on the front you shouldn't have much issue with anything else.
    A block/spacer is fine in the rear for a cheap lift.
  3. Oct 13, 2021 at 12:32 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    You don't need a lift for those tires. But if you do want to use a spacer, keep it small. Otherwise, much better off using a quality front coilover. And even then, keeping it under 3" of lift will help your CVs
  4. Oct 14, 2021 at 8:56 AM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    No way I would feel safe using those U bolt replacements at that package price, and I don't think you'd be happy long term with any of that. Some things you can not scrimp on. Save your money.
    mose1117[OP] likes this.
  5. Oct 14, 2021 at 9:18 AM
    mose1117
    Sacramento,CA
    2015 DCSB TRD SPORT
    Might bump up to 275's but prolly not bigger than that.....would those still clear?
  6. Oct 14, 2021 at 9:26 AM
    YF_Ryan
    Kent, WA
    I HIGHLY doubt that. The width is more the problem at that point than the height/diameter of the tire. You can go Skinny and taller, but not wider. My 265/75r16 Duratracs Just barely rub on my mudflaps (aftermarket ones). Any wider and they'd rub pretty bad.
