Leveling/Lift Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wattapunk, Feb 26, 2010.
  1. Feb 26, 2010 at 7:10 AM
    Wattapunk
    Wattapunk [OP] Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    I have a '05 Tacoma DC LB 4x4. Considering front toytec coilovers to level the truck out. I know spacers are cheaper but wanted the option for possible lift upgrades in the future. I measured the fender/tire gap difference of the truck in my garage last night.(tires less than 5000 miles) The rear is 2.25 inch higher than front. Plan on toytec coilovers for the front only and keeping rear stock. Will this work or do I need 1" blocks for the rear? Also will that little 1" blocks cause any ride stiffness or axle issues if its the truck is not used for Offroading. I want to keep the factory ride..Thanks for all the help.
  2. Feb 26, 2010 at 7:52 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Welcome.
    The coilovers will work great for leveling the front with the back. If you want to put the one inch block in the back, shouldn't be a problem. Many people stay away from blocks, but with just the one inch, you should be fine.
