Leveling with 5100s non rear TSB
Discussion in 'Suspension' started by primer, Jun 8, 2012.
  1. Jun 8, 2012 at 7:23 AM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Posting this b/c I never could find an answer to this q. Hopefully this helps someone.
    Started from stock suspension front and back. No rear TSB. Wanted to level my truck. Lots of posts say 5100s at 1.75 with rear TSB make you level. Never could find out if that would make me nose high (which i absolutely did not want) without rear TSB.
    Pulled the trigger. Looks level. Not nose high. Couldn't find my tape measure, but a level on the bed says I'm maybe 1/2 degree tail high. Just what I wanted.
    Just putting this out there in case someone is looking for that info.
  2. Jun 8, 2012 at 9:54 AM
    Holyfather
    Holyfather Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    Ya I set mine at 1.75" and my front is only about .25" lower than my back
  3. Jun 8, 2012 at 12:57 PM
    primer
    T
    OK
    Yup - 5100s up front set at 1.75", 5100s rear with stock (non TSB) leaf springs. Put me perfectly level, to very slightly tail high.
  4. Jun 10, 2012 at 2:24 PM
    DestroyerFan
    DestroyerFan Well-Known Member
    SoCal
    09 MagGray PreRunner SR5 Sport
    When you went with the 5100's did you have to change your springs?
  5. Jun 10, 2012 at 4:52 PM
    primer
    T
    OK
    No
  6. Jun 11, 2012 at 4:45 PM
    Landon8503
    Landon8503 Member
    Landon
    Alabama
    2011 TRD 4x4 Sport dc lb
    Thanks...going to put my 5100's on this week and was wondering if I needed anything for rear after going 1.75 up front.
