Leveling with tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rzaucha, Aug 6, 2010.
  1. Aug 6, 2010 at 6:39 PM
    rzaucha
    rzaucha [OP] Big Member
    Sacramento
    If it ain't broken, I'll fix it.
    Rancho RS66901R9 upfront, Emu Leaf Pack in rear, 285/70/R17 BFG TKO 2's, Snugtop, TRD CAI, TRD Exhaust System, Thule Rack, JL Audio Stealthbox, Focal Access 165A1 SG, Pioneer AVH-X5500BHS, JL Audio XD500/3
    Just FYI for anyone out there looking to go up in tire size. I put on a 2.5" Daystar leveling kit on a 2010 V6 4x4 Access Cab Tacoma and was able to clear 285/70/R17 BFG ATs. Don't need to take off front mud flaps, and maybe a couple millimeters rub with wheels cranked all the way.
  2. Aug 6, 2010 at 6:41 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2008 P71
    Yes
    Millimeters!:eek:
  3. Aug 6, 2010 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It varies truck to truck. Some may have very minimal rubbing, while others will rub like crazy.
  4. Aug 7, 2010 at 7:16 AM
    ycart1201
    ycart1201 Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    right on.
    Nathan
    ycart1201
  5. Aug 7, 2010 at 3:01 PM
    cagle1
    cagle1 New Member
    Alabama
    07 dc trd sport 4x4
    Did you not have to run spacers with the factory wheels. Everywhere I have read said it would rub the uca's with 285's.
  6. Aug 7, 2010 at 3:05 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,295 BFG KO2'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    Hows the ride i wana add the leveling ki???????
  7. Aug 10, 2010 at 12:06 PM
    rzaucha
    Sacramento
    Ride is fine. If anything, softer than stock. No spacers added. It does rub the UCA; however, it only happens when the steering is fully turned, and even then, it's barely noticeable.
  8. Aug 10, 2010 at 3:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Please expain how the ride will be softer than stock, when using spacers?
  9. Aug 10, 2010 at 3:29 PM
    wareagle5693
    wareagle5693 Well-Known Member
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    3" Spacer Lift, with Bilstein 5100s front and rear, BHLM, Satoshi grill, Blacked out tail lights, Midland CB radio, 4' Radio Shack antenna mounted in the bed, Volant CAI, Gibson Exhaust, Magellan GPS, debadged, aries bull bar, pro comp 7089 wheels, Pioneer DEH-P6200BT head unit, eagle eyes halo projector, 8000K DDM tuning HID bulb
    This confuses me too... they aren't softer than stock..
  10. Aug 10, 2010 at 4:20 PM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    Why is that? Same setup should equal same results?
    I seem to be one of the un-lucky ones. I am running 265-70-17's with 2.5" up front and aftermarket wheels and I rub my mudflaps. I was hoping to squeak on some 285's with the greater offset of my new wheels, but now I am thinking that is not going to happen.
  11. Aug 10, 2010 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Unless the OP put in softer springs, the ride will be more firm than stock.
    Production variences. If the vehicles were dimensionally, and physicaly identical, then all the results would be the same. However, there are slight differences vehicle to vehicle.
  12. Aug 10, 2010 at 5:19 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    did you do an alignment
  13. Aug 10, 2010 at 5:22 PM
    dw77x
    SE Wisconsin
    Yes I did, it is very minor and equal on both sides.
  14. Aug 10, 2010 at 5:28 PM
    David Tarantino
    N.J.
    08 tacoma
    i would like to see the no#s on that if you don't mind :)
  15. Aug 10, 2010 at 5:37 PM
    dw77x
    SE Wisconsin
    Honestly I don't have the sheet anymore (if I did I would be happy to share). I had the alignment done after I put the lift (5100's) on and got the tires, this was about a year ago. Last week I got new wheels and the minor rub. All I need to do is take my die grinder to the inner part of the flap and I will be fine. I may even take a flap off to measure clearance for my 285 dream.
    I only go to a very reputable shop I trust (nearly an hour from my house). They specialize in cars and trucks with aftermarket wheel/tire/suspension setups.
    **Plug > Big Bear Tire Oconomowoc Wisconsin!
  16. Aug 11, 2010 at 9:58 AM
    rzaucha
    Sacramento
    I can't explain it anymore than it just feels softer up front. May be the larger tires, may be the spacer. Duno.
  17. Aug 27, 2010 at 11:57 AM
    hockeypoor
    hockeypoor Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Daystar spacers are made from a bushing like material. polyurethane I think. Most other spacers are steel or alum.
    With the poly spacers and combo of the larger sidewalls on the tires the front end will have more give in it making it feel softer.
