Lexus Credit Card Key Working in Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Aug 15, 2016.
  1. Apr 12, 2019 at 6:19 PM
    #521
    Txsrooster
    Txsrooster Well-Known Member
    I got my card working today...and while I was at it, I added a smart key to the wife's Highlander since it only came with 1 key.
  2. Apr 13, 2019 at 8:59 AM
    #522
    Victory
    Victory [OP] Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    The same part number for the Lexus key should work for the Highlander also if you want a credit card key for both your vehicles.
  3. Apr 13, 2019 at 12:05 PM
    #523
    Txsrooster
    Thanks for the tip.
  4. May 7, 2019 at 1:53 PM
    #524
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    For those that have had the credit card style emergency key cut, I assume only one side can be cut? Is the Tacoma key double sided? Will a cut on one side work? TIA.
  5. May 7, 2019 at 2:37 PM
    #525
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    The 3rd gen Tacoma key is grooved on one side. Same key size as the Lexus emergency cc key.
  6. May 21, 2019 at 7:58 PM
    #526
    hzqTRD62
    hzqTRD62 Well-Known Member
    HQ
    Lewisville
    2016 Tacoma TRD OFF ROAD 4x4
    Retro fit Head light, Katzkin Leather up grade and O.E.Audio
    I need help Guys, I purchase the Lexus Credit Card key, could not get to Program with my 2016 Tacoma? any Suggestion or advice Please, Key Part Number 89904-53511. Thanks
  7. May 22, 2019 at 7:36 AM
    #527
    Victory
    St. Pete, FL
    How did you try? Doing it yourself with a copy of techstream? Going to a locksmith? New key or used key? Was there an error, or just doesn’t work?
  8. May 22, 2019 at 8:37 AM
    #528
    Txsrooster
    New key or used? Are you using techstream and if so does it find and connect to your truck? What steps are you taking and where does it fail at?
  9. May 22, 2019 at 4:32 PM
    #529
    hzqTRD62
    HQ
    Lewisville
    Hello Sir, thanks for your response, yes it is new key, luckily work for Lexus dealer in the area, so have Master tech assisting me, scanner did not recognize the key card, did match all the numbers and code on both keys?
  10. May 22, 2019 at 4:36 PM
    #530
    Victory
    St. Pete, FL
    We have had some reports of keys coming with dead batteries. Sounds like that is probably something to check. I can’t think of any other reason this wouldn’t work if it is a new key and you are using a dealership computer
  11. May 22, 2019 at 4:44 PM
    #531
    hzqTRD62
    HQ
    Lewisville
    I will have him replace the Battery Friday and try it again, will keep you posted on the out come, thanks for your prompt response. H.Q.
  12. May 22, 2019 at 4:45 PM
    #532
    Victory
    St. Pete, FL
    Good luck. Seems these must sit on shelves a long time and batteries die. It is a little hard to find the size needed. You may need to order from Amazon or batteries plus.
  13. May 22, 2019 at 4:47 PM
    #533
    hzqTRD62
    HQ
    Lewisville
    Actually I will get with no cost to me from the Dealership, we should have them in stock,
  14. May 25, 2019 at 8:35 PM
    #534
    hzqTRD62
    HQ
    Lewisville
    Thanks, for your help, it did work after replacing the Battery. Best regards
    Txsrooster likes this.
  15. May 26, 2019 at 6:32 AM
    #535
    Victory
    St. Pete, FL
    Great! Glad I could help
  16. May 26, 2019 at 3:11 PM
    #536
    hzqTRD62
    HQ
    Lewisville
    You are great help,Sir thank you
  17. Jun 5, 2019 at 9:34 AM
    #537
    Kirk5370
    Kirk5370 Well-Known Member
    Toronto, Ontario
    2017 DCLB TRD Sport +
    Clazzio, Weatherbeaters, Softopper
    Anyone know if this will work with 89904-53512 keys??
    Seems like you cannot buy 89904-53511 on partznet
  18. Jun 5, 2019 at 10:20 AM
    #538
    Kirk5370
    Toronto, Ontario
    Hey Victory; are there more than one part numbers for this cc key? I've found some online for decent prices but they list it as a HYQ14ABB smart key - no mention of 89904-53511
  19. Jun 5, 2019 at 10:30 AM
    #539
    Victory
    St. Pete, FL
    No. You need the part number listed on the original post. 89904-53511 with FCC code HYQ14CBB.
    A quick google search and I found many online (including partznet) for sale with the correct part number, maybe check the number you searched and try again?
  20. Jun 5, 2019 at 10:31 AM
    #540
    Kirk5370
    Toronto, Ontario
    Yea sorry - just being cheap. I found some used ones with the same HYQ14CBB code - does this mean the PN will be the same as well? Or am I rolling the dice?
