Lexus Credit Card Key Working in Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Aug 15, 2016.
  1. Feb 22, 2022 at 6:19 AM
    #721
    DesertTaco21
    DesertTaco21 Well-Known Member
    Kyle
    2021 Bule Tacoma TRD Off-Road
    None yet
    Thanks for all your help Victory, I'll probably start by calling around to some local autolock places and seeing if they can or will do it before I go the techstream route
  2. Feb 22, 2022 at 7:57 AM
    #722
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    I haven’t tried an add smart key function yet, but as far as other customizable settings I’ve been able to use the older version of techstream and manually input the vehicles as a 2020. I’ve used it on 21 & 22 Tacomas.
    Victory[QUOTED][OP] likes this.
  3. Feb 22, 2022 at 12:10 PM
    #723
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    So I have the 2 day subscription to tech stream and using a tactrix dongle. Everything worked as described leading up to adding the key card, but the only issue at the end was the card was already registered to another vehicle. This is a show stopper. Anyone know of a way to make it a virgin card again?
  4. Feb 22, 2022 at 3:13 PM
    #724
    cemented
    Cole
    Portland, OR
    I used this service. Real quick turn around time. Read everything and make sure your battery is charged.
    https://www.ebay.com/itm/Unlock-SER...mote-HYQ14CBB-HYQ14ABB-HYQ14AEB-/154310955898
    BigWhiteTRD likes this.
  5. Feb 22, 2022 at 3:46 PM
    #725
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Do you have a link? I'm curious of the cost vs buying tokens or a new card.
  6. Feb 22, 2022 at 5:53 PM
    #726
    virginiamarine
    Northern Virginia
    EagleUSMCRet and dilbert like this.
  7. Feb 22, 2022 at 7:55 PM
    #727
    cemented
    Cole
    Portland, OR
    Sorry I got lost in my response earlier. Edited with link.
    BigWhiteTRD and dilbert[QUOTED] like this.
  8. Feb 22, 2022 at 8:54 PM
    #728
    dilbert
    dilbert AI Member
    PNW
    Thanks, not a bad price either vs buying a token.
  9. Feb 22, 2022 at 10:16 PM
    #729
    cemented
    Cole
    Portland, OR
    The response time was super fast. I’m pretty sure they received it and shipped it the same day. I was able to program it for a friend’s truck with no issues.
  10. May 10, 2022 at 9:19 PM
    #730
    whoops
    whoops Member
    Dave
    Rockland County, NY
    2024 TOYOTA LC 250
    UPDATE:
    After getting the key re-virginized with a service out of PA I successfully programmed my key card yesterday on my 21 trd off road.
    edit:
    Used key
    HYQ14CBB
    If anyone wants the service I used pm me and I'll send you the link, I don't know if links for services are frowned upon.
  11. May 12, 2022 at 5:37 PM
    #731
    whoops
    whoops Member
    Dave
    Rockland County, NY
    2024 TOYOTA LC 250
    Used this with TIS activated off MHH.
  12. Aug 9, 2022 at 4:58 PM
    #732
    Broadrunner
    Broadrunner Well-Known Member
    Anybody able to successfully add a credit card key with Tech Stream Version 17?
  13. Aug 9, 2022 at 6:11 PM
    #733
    JCGarfunkel
    JCGarfunkel Well-Known Member
    Peter
    VA
    2016 Silver Tacoma TRD OR DCLB
    Doing this mod has ruined carrying a normal set of car keys for me. I’d be devastated to have use a normal fob again
    EagleUSMCRet, cemented and RyanDCLB like this.
  14. Aug 10, 2022 at 4:18 AM
    #734
    Broadrunner
    cemented likes this.
  15. Aug 11, 2022 at 8:51 AM
    #735
    Jord4n007
    Jord4n007 Active Member
    Jordan
    New Orleans
    2022 TRD Sport Double Cab Magnetic Gray Metallic
    RetraxProXR Roll-up bedcover, Uniden R8 Radar Detector with mirrortap/mount, Husky X-act Contour floormats, MESO Hex Rack, MESO Mini Keypad Dongle, MESO Fuse Block, Carlinkit Android dongle (gives you fully unlocked android OS through factory touchscreen, youtube/netflix/etc and wireless apple carplay)
    Has anyone had success with this on a 2021 or 2022 Tacoma? Is there any reason to suspect it might not work the same? I really want to try but the OP says its for 2016-2020.....
    Barsoom likes this.
  16. Aug 19, 2022 at 9:14 AM
    #736
    A-ron
    A-ron YotaWerx Authorized Pro Tuner - Colorado
    Aron
    Colorado
    21 TRD Sport - Cement
    YotaWerx Blackhawk 2.1 Tune, TRD Lift, DV8 front bumper, DD SS3 Pro Fog Lights, DD Stealth Light Bar, 4Runner Wheels, Leather Seat Covers, Morimoto Tails, Meso sequential mirror lights, Ect button relocated to shifter,
    No go on my 2021 sport. ECU matches, but my FOB does not have the AG letters, just G. Anyway, it will not recognize the new from dealer Lexus key card. I am going to try to switch out the battery to see if that makes any difference. Everything is the same as OP with the exception of my FOB. Not sure if I am doing something wrong, but I go through the process in techstream and cannot get a beep when I get to the step of registering the key card. Bummer
  17. Aug 19, 2022 at 9:23 AM
    #737
    Broadrunner
    What version of Techstream are you using? When you try to register a new key fob, do it make you go through the process to get a pin code?
  18. Aug 19, 2022 at 9:41 AM
    #738
    A-ron
    Aron
    Colorado
    I am on Ver 16.20.023. I can get as far as the step to hold the new key you are trying to register up to the start button, but the truck never beeps or recognizes the Lexus key card, and the process times out.
  19. Aug 19, 2022 at 9:42 AM
    #739
    A-ron
    Aron
    Colorado
    It never says anything about a pin code.
  20. Sep 24, 2022 at 5:52 PM
    #740
    proomegaman
    proomegaman New Member
    Hi guys. 4Runner guy here. Thanks for this marvelous thread, thanks to the OP Victory, and all those that contributed. I read all 37 pages so no real questions on this as you all answered the same ones repeatedly for people! Victory addressed another 4Runner owners question and said maybe a different part number. Another 4Runner owner said on the 4R forums that the part you all are running works! I am excited to give this a shot. I don't see the numbers listed on the ebay listings anymore but its worth taking a gamble anyway. Worst case its wrong and I return it. I plan on paying the small premium to get it from ebay for that convenience.
    I also can't confirm my ecu number as I have no clue where that is but if its worked for all of you, why wouldn't it work for me on a 2020 4R Pro?
    If anyone in the Bergen County NJ area knows of a good locksmith please let me know. I plan on calling a hundred places until I find one who isn't looking for a mortgage payment in return.
    Great forum you have here. I appreciate all the helpful insight you share without it being snarky. Thanks everyone!
