Lexus F sport LEDs fog lights on 2016 Tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by juan1028, Aug 27, 2016.
  1. Aug 27, 2016 at 6:42 PM
    juan1028
    juan1028 [OP] Well-Known Member
    juan
    2016 Tacoma TRD OFF ROAD
    TRD OFF ROAD inferno color .
    100 % sure , second generation and third generation use the same fog lights , on the second generation you have to remove the black plastic cover and do it from the back , and the H11 plug should just plug in with no adapters .
    HNLSFO1, stealthmode and o0oSHADOWo0o like this.
  2. Aug 27, 2016 at 6:45 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    @TRD2010SpeedwayBlue 2012+ only
    TacomaArto likes this.
  3. Aug 27, 2016 at 6:47 PM
    juan1028
    juan
    Excellent point , they did changed the fog lights on the 2012 refresher .
  4. Aug 27, 2016 at 9:18 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    ahh so no good on my 2010. :(
  5. Aug 27, 2016 at 9:22 PM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Nice job! If I wasn't getting a plate bumper I'd definitely do this upgrade...
  6. Aug 28, 2016 at 12:54 AM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    only if the 2nd gen is exactly the same as the 3rd gen??
  7. Aug 28, 2016 at 1:17 AM
    easbaysav
    easbaysav Well-Known Member
    Eddie
    Central Valley, CA
    2019 TRD Off Road AC Cement
    Good find OP. Those fogs look good both day and night. I already bought some Baja Design fogs from another member, but if I didn't, I'd jump pick up a pair of these.
  8. Aug 28, 2016 at 1:23 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Great find OP. Hmm might just be changing out my XB Led Fogs to this.
  9. Aug 28, 2016 at 6:33 AM
    se7en
    se7en Go Vols!
    East TN
    25 TRD PRO - Ice Cap
    I just ordered a set for my Limited. The fogs on this truck are the worst ever...just about useless. I've got the lowly H16's with plastic lens covers. Just pathetic!! Have been looking for replacements, and this is just about as good as it can get as far as OEM, I think.
    Question, though...I can't tell from your photos, but do these mount perfectly flush against the bumper on the inside? If someone didn't know better, would they be able to tell that these weren't stock from the factory? Too late for me, now, as I've already ordered a set, but curious.
    HNLSFO1 and Bob259 like this.
  10. Aug 28, 2016 at 6:34 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Wish these would fit 2011....
  11. Aug 28, 2016 at 6:45 AM
    Gerdaland
    Gerdaland Well-Known Member
    Blake
    2016 Tacoma TRD Off-Road Double Cab
  12. Aug 28, 2016 at 7:25 AM
    juan1028
    juan
    They fit identical to the OME original fog lights, Plus they are projector LEDs so it does give you a decent light pattern. the swap is extremely simple , one screw , unplug the light and pull it out , reverse the process to install new ones . ( from the top by the grill , no need to remove any thing.)
    HNLSFO1 likes this.
  13. Aug 28, 2016 at 7:28 AM
    juan1028
    juan
    they only fit 2012 and up Tacomas , and 2014 and up Tundras.
    omaguz likes this.
  14. Aug 28, 2016 at 8:29 AM
    se7en
    se7en Go Vols!
    East TN
    Perfect!! Thanks...and I'll post up once mine are installed. These are more expensive than the Morimoto XB's, but they're OEM. As far as output, practically ANYTHING is better than the stocks on the Limited.
    HNLSFO1 likes this.
  15. Aug 28, 2016 at 8:15 PM
    #35
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Wait... what? Smitty something actually works on your truck?? That's awesome!
    Side note ... I replaced my stockers with LEDs and those Lexus lamps are exactly the same as the stock from Tacoma. Same shape same adjustment knob everything. I've been looking at other Toyotas and there's other parts that are the same as well. Not surprising....
    HNLSFO1 likes this.
  16. Aug 28, 2016 at 8:17 PM
    #36
    bobrown14
    Bob
    Philadelphia
    Gen 3
    You had to do the same thing on your truck ... just to clarify, right? Remove black bezel and unscrew from the back which is a PITA but not that hard replace lamp and re-install bezel.
    HNLSFO1 likes this.
  17. Aug 28, 2016 at 9:44 PM
    #37
    the_dau
    Vancouver BC
    so aside from being able to say they're a lexus part, is there any reason you'd recommend this over something like the TRS led fogs? Seems like the output on the TRS fog is better
  18. Aug 28, 2016 at 10:10 PM
    #38
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    There are several factors to light output, in using lumens amount, dispersion, cut off, etc. I'm no expert so can't say how these will compare to aftermarket offerings, just FYI.
    Seems that around here, running fog lights (and needlessly blinding everyone) is a fashion statement more than anything else (I see fog maybe once per year), so bling bling.
    Rising Eagle likes this.
  19. Aug 28, 2016 at 10:11 PM
    #39
    the_dau
    Vancouver BC
    from pictures I've seen of the TRS fogs, they have a pretty clean cutoff . I don't see those being very blinding unless you're behind a lowered vehicle
  20. Aug 28, 2016 at 10:14 PM
    #40
    0210
    Vancouver, BC
    I mean fogs in general, not those specifically. In my lifted Tacoma I get blinded by low sitting coupes and sedans every few minutes. And occasionally there's the ferd fteeeen-thousand on a 12" lift with four sets of halogen-housing-mounted HIDs riding my ass, but those guys will always be "special."
    the_dau[QUOTED] likes this.
