  1. Jul 16, 2021 at 9:06 AM
    Hogbaseball06
    Hogbaseball06 [OP] Well-Known Member
    2021 Cement Trail Ed.
    Looking for someone to do a cement gray color matched taillight mod or a thread to someone that does it. Thanks in advance
  2. Jul 16, 2021 at 9:07 AM
    Tacospike
    Two Trucks
  3. Jul 16, 2021 at 9:09 AM
    Hogbaseball06
    Thanks, he's finishing up a set of headlights for me. I believe I asked him about tails in the beginning and he told me no. But I'll have to go back and double check!
    Tacospike[QUOTED] likes this.
  4. Jul 16, 2021 at 9:36 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The issue with taillights, is that they are not glued shut, they are plastic welded shut. Therefore, to open them up, you need to surgically cut them open. It's an intensive process that very few have completed. The only person I know for sure has done it, is @MESO, but he does not do contract work...
    Good luck OP! Your best bet may be buying a set of spare tails and trying your hand at cutting them open. Not for the faint of heart.
    Tacospike and Frsh2df like this.
  5. Jul 16, 2021 at 10:01 AM
    Hogbaseball06
    Thanks. I figured that might be the case but I'm hoping someone has the process down already and is willing to help me out.
    Bertw192[QUOTED] likes this.
  6. Jul 16, 2021 at 10:07 AM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    Probably cheaper to just buy the 20-21 pro headlights and attempt to sell yours.
  7. Jul 16, 2021 at 10:13 AM
    Hogbaseball06
    except 20-21 don't come in cement..but yes that's my alternative course of action
  8. Jul 16, 2021 at 10:48 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Taillights... not headlights... Right OP? o_O
  9. Jul 16, 2021 at 10:52 AM
    Hogbaseball06
    Yes correct. Thanks for catching that. Cement Grey headlights are headed my way in the next 7 days or so
  10. Jul 16, 2021 at 10:57 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    People are getting confused, because BTLM's are so rare, that people are assuming you meant BHLM... Kind of shows you the uphill battle you have ahead of you.
    For you're viewing pleasure... Check out the white set...
    https://www.tacomaworld.com/threads...-3-sets-trd-off-road-pro-stormtrooper.521649/
  11. Jul 16, 2021 at 11:04 AM
    Hogbaseball06
  12. Jul 16, 2021 at 11:07 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    HIGHLY doubtful... but fingers crossed for you. Much more likely/hopeful is that they use retro rubber to seal them up, so they can be "easily" split open.
  13. Jul 16, 2021 at 11:25 AM
    Hogbaseball06
    Hey a guy can dream! A close 2nd would be retro rubber to seal them.
  14. Jul 16, 2021 at 2:33 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I have a set of 20/21 LTD that MESO cut open for me (for essentially the same reason - MGM, and some other sorcery) I have the skills/knife (sonic) to do the same again. I really only do things for myself, but I’d consider cutting a pair open for you if you paid back/forth. I don’t think you can retro-rubber the cuts, except maybe to secure the seal. The cuts aren’t at the clear/black line, but rather where it makes the process easiest and can be hidden from view when installed. This is often in the black a 1/4” - 1/2” in from the edge. Suture back via plastic weld, which is what he did.
  15. Jul 16, 2021 at 2:37 PM
    Hogbaseball06
    Can you PM me your zip code. Definitely be interested in talking more about this
