Lifetime LED Install and Review In Progress
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RearViewMirror, Apr 11, 2014.
  1. Apr 14, 2014 at 2:42 PM
    #101
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Go back a few pages and I posted pictures of the difference between high and low beams. No fix needed.
  2. Apr 14, 2014 at 2:45 PM
    #102
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I have had these in my headlights and fogs for 8 months now couldn't be more satisfied replaced the HIDS and will never own hids again
  3. Apr 14, 2014 at 2:47 PM
    #103
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    I have LED headlights on my truck (look exactly like these) and I really love them. Bright white light and looks really cool.
    I have a question about interference with the FM radio. When I turn my headlights on I get some static. As soon as I turn them off it goes away. Is there anything I can do to prevent it? Thanks
  4. Apr 14, 2014 at 3:12 PM
    #104
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    Processed
  5. Apr 14, 2014 at 3:15 PM
    #105
    kd8bao
    Henry
    Cleveland
    1 or 2 stations have very little static. But I get the same with geographic location. Maybe a ferrite choke on the positive wire. I have some at home I will see if it helps tomorrow.
  6. Apr 14, 2014 at 4:38 PM
    #106
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Thank you!
    I actually just found out something else that also works. I was told that if the drivers and cables/wires are touching the metal (fender etc) it may cause interference. I had double sided tape holding the drivers down but the cables/wires were touching metal. I zip tied them up and no more static.
  7. Apr 14, 2014 at 5:33 PM
    #107
    kd8bao
    Henry
    Cleveland
    Very nice. I will get mine off fender as well. Thanks
  8. Apr 14, 2014 at 5:47 PM
    #108
    kd8bao
    Henry
    Cleveland
    Got it all squared away.:D
  9. Apr 15, 2014 at 7:02 AM
    #109
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
  10. Apr 15, 2014 at 7:08 AM
    #110
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Considering these, but thought occurred to me yesterday: Has anyone installed/tested these under extreme cold conditions? I'm talking down in the -20F to -40F range. :popcorn:
  11. Apr 15, 2014 at 7:16 AM
    #111
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    You're going to have problems with the housing freezing over, but I don't think the light itself is going to be a problem. The LEDs run cooler than halogen and so won't be able to defrost the front at those temps. (I assume)
  12. Apr 15, 2014 at 7:17 AM
    #112
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Peter (LoadedTaco) should be able to tell you since we had a few days at those temps this winter
  13. Apr 15, 2014 at 7:22 AM
    #113
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Good to hear. I will say this just so people have options-The LED setup is better than OE Halogen and is better than a pnp HID setup as far as light dispersion is concerned but to get the best lighting a true HID retrofit is still the way to go. Now, if you don't want to mess with splitting your headlights apart and want a quick and easy setup that provides results then it seems the LED kit is a no brainer.
  14. Apr 15, 2014 at 7:26 AM
    #114
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    Order placed on wiredinstallation.com, #165.
  15. Apr 15, 2014 at 7:28 AM
    #115
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Wow. 8 months. Looks like I'm going to have to get some of deez.
  16. Apr 15, 2014 at 7:40 AM
    #116
    RearViewMirror
    Craig Christ
    I won't argue that. Retrofits are definitely nice and a quality retrofit will put out good light. I honestly just didn't feel like pulling the lens on these lights. The factory lights on the Tacoma are actually some of the best lights I've had in a vehicle. These LED's make them even better with little modification. No doubt though the HID correctly done is very nice indeed.
  17. Apr 15, 2014 at 7:58 AM
    #117
    Bunk454
    Bunk454 Well-Known Member
    Huntsville, AL
    '13 MGM DCSB TRD Off-Road
    Order #166 just placed!
    Thanks.
  18. Apr 15, 2014 at 8:05 AM
    #118
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    Wut
  19. Apr 15, 2014 at 8:07 AM
    #119
    RearViewMirror
    Craig Christ
    Cool story bro!
    Now put it in the +40 thread loser :p
    *EDIT* Unless you put the headlights on your surfboard.
  20. Apr 15, 2014 at 8:09 AM
    #120
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :rofl:
    That's our boy PorkChop. :D
