Lift and Suspension Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by takates, Nov 15, 2017.
  1. Nov 15, 2017 at 4:56 PM
    takates
    takates [OP] Member
    Sean
    2011 Toyota Tacoma Extended Cab V6 SR5
    Bilstein 5100 shocks and coil overs with 2" lift in front, 1.5" in back
    I installed the following last year, and have noticed that my front end sank down a little after doing it.
    - Bilstein 5100 Series Shock Kit for Toyota Tacoma 4WD & Pre Runner 2005-14
    - Bilstein Front Ride Height Adjustable Shocks # 24-239370 & Rear Shocks # 2
    - Icon Vehicle Dynamic Toyota 1.5 Lift Leaf Springs in Rear
    - Helo HE878 17x9"/6x139.7mm, -12mm offset
    - Nitto Terra Grappler G2 285/70/17 Tires
    - ** Stock Coils **
    After installing the everything (setting the Front shocks to 2"), I noticed that it started sinking after about a month (which I expected a little sinking). Now, it has dropped about 1.5" compared to the back. I was thinking about getting 2" leveling spacers for the front, but wanted to know if this is the right way to go about fixing the issue. I get a lot of tire rub from hard turns (because it's too low) and want to resolve this.
    Thanks for any advice in advance.
  2. Nov 15, 2017 at 4:57 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    :sawzall:
    jeff b likes this.
  3. Nov 15, 2017 at 4:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Stock Coils or aftermarket Coils
  4. Nov 15, 2017 at 5:00 PM
    takates
    takates [OP] Member
    Sean
    Stock, sorry about that. Also any recommendation in aftermarket coils would be excellent.
  5. Nov 15, 2017 at 5:01 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Replace your stock coils with some Aftermarket. Your ass will thank you also because it will ride alot better than preloading those stock coils.
  6. Nov 15, 2017 at 5:03 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have the ICON 3 Leaf Progressive AAL in the back with the overload in and OME 887's up front on 5100's. Gave me 3 inches up front and 2 inches in the rear
  7. Nov 15, 2017 at 5:22 PM
    takates
    takates [OP] Member
    Sean
    Thanks Rick. What is the main difference between OME 2886 and 2887? OME guide recommends the 886, but I do a lot of heavy load transports.
  8. Nov 15, 2017 at 5:23 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    886's are usually for armor up front
  9. Nov 15, 2017 at 5:30 PM
    Chase8059
    Chase
    ESVA
    I have the exact same setup with no complaints.
    Our trucks don't have "coils" on the rear, we have leaf springs. Your factory pack with the AAL should be fine if your issue is with sagging in the front end.
  10. Nov 15, 2017 at 5:31 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Forgot to add I have ICON 2.0 shocks in the rear, and JBA Standard High Caster UCA's up front
  11. Nov 15, 2017 at 5:33 PM
    Chase8059
    Chase
    ESVA
    I gots them jbas also, but Fox 2.0 RR w CD adjustors in the rear. So we are almost twinning. :rolleyes:
  12. Nov 15, 2017 at 6:01 PM
    takates
    takates [OP] Member
    Sean
    Thanks guys, really appreciate it. Just purchased some OME coils, will take a before and after picture...excited to finally fix this!
  13. Nov 16, 2017 at 5:05 PM
    takates
    takates [OP] Member
    Sean
    One last question. I was reading in a few other threads about total lift. I ordered the OME 2886 coils and was reading, I should leave the 5100 at the stock setting of 0 for a 2" lift? Or, should I set it at 1" being that it may go down a little when the coils settle in?
  14. Nov 16, 2017 at 5:07 PM
    Chase8059
    Chase
    ESVA
    It's not recommended you preload aftermarket coils with the 5100s. I don't know much about the 886 coils except that they have a higher spring rate than the other coils by OME.
  15. Nov 16, 2017 at 5:14 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Set the 5100s to 0 with the 886s. If you don’t have a steel front bumper, winch and skids you’re probably going to regret those stiff coils and end up with a 4” front lift.
  16. Nov 16, 2017 at 6:25 PM
    takates
    takates [OP] Member
    Sean
    Thanks for the advice guys. I plan on getting skids and a bumper soon, so decided to go a little stiffer.
