Lift and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Casey05Taco, Sep 1, 2008.
  1. Sep 1, 2008 at 9:53 PM
    Casey05Taco
    Casey05Taco [OP] Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Ok so im new to the Tacoma and my friend says he has a set of BFG 285/70/R17. What does this mean? I know what 33's and 35's are and stuff but i dont know what these letters mean. I know this is really noobish but any help would be great. Im looking also at putting some 33's on my truck with 18' moto metals in black. How much lift would i need?
  2. Sep 1, 2008 at 9:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you should go with a 3 inch lift, as that will probably work, and with the 285's....you still may need to trim a bit or remove the mud flaps, but im not exactly sure. use this to figure out the exact difference between the stock tire size, and the ones you wanna go with.
    http://www.tacomaworld.com/forum/tirecalc.php
  3. Sep 1, 2008 at 10:10 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    I have no idea what the 285's mean lol. All i know is the term 33's and such
  4. Sep 1, 2008 at 10:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a 285 tire is alot wider and bulkier than say a 265.......so you would need a lift and possible trimming to fit 285 tires on your truck.
    what size are the stock tires??
  5. Sep 1, 2008 at 10:16 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    285 is the width of the tire (in millimeters), 70 is the % of width in the sidewall 17 is the wheel size. This is called Metric Size.
    A 285/75 tire is a 33" tire. To fit you will need to trim inner fender wall as well as the mudflaps and a lift.
    Edit:
    OP: Your stock tires are 265/70/16. With a 3" lift, most people go with a 265/75/16 tire (no trimming needed) or a 285/75/16 (slight trimming needed). The ladder being the most popular option. I personally don't really want to bother with trimming or the higher cost of the 285s, so I will be going with 265/75/16 on stock wheels when I lift in a few months.
  6. Sep 1, 2008 at 10:26 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    So how much trimming would you think id need if i went with a 285/70/R17?
  7. Sep 1, 2008 at 10:33 PM
    Khaos
    Khaos Big Member
    Bryant
    Not much. Just a little on the plastic and probably remove the mud flaps.
    What I would do is mount them and drive normally for a week so that you have some marks of where its rubbing and then you can just trim accordingly.
  8. Sep 1, 2008 at 10:57 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    ok sounds good. THanks for the help. ANy good suggestions on a good lift just for looks?
  9. Sep 1, 2008 at 11:03 PM
    Khaos
    Khaos Big Member
    Bryant
    What kind of budget?
    Check out the FAQ link in my sig, it should give you a ton of info on what you're looking for.
  10. Sep 2, 2008 at 12:46 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    here is a pic of a 285, I had to remove the front flaps, and do minor trimming. EASY!!
  11. Sep 2, 2008 at 8:28 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    THat looks good. i think when im ready and can pay for it ill get with these
  12. Sep 3, 2008 at 8:24 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    My 285/75 16's were technically 32.8" tall, and 11.something wide. I did not need to trim any of the plastic since they didn't rub. They did, however, rub the UCA's slightly on lock-to-lock turns. Wheels with different BS can be used to run them without rubbing the UCA's, but then you need to trim the body mount because that becomes the new rub point. I'm cheap and lazy so I stayed with stock wheels and let it rub the paint off the UCAs. My new set of tires (waiting to go on as we speak) are 265/75 16's so they're slightly narrower and an inch shorter (31.8" or something like that). So I definitely will not need to trim for those. :D Cheaper too. :eek:
  13. Sep 3, 2008 at 10:59 PM
    2nd2none
    2nd2none Well-Known Member
    San Diego, CA
    2018 Tacoma TRD Pro. Lifted, rims, tires, yada yada yada
    I used to have 285/75/16s but even after removing my front mud flaps and trimming a lot i was still rubbing. I'm running with DR coilovers and TC UCAs up front. Is there something you can have done with the alignment to I guess push the front wheels up closer to the front of the truck? I read about people all the time running the 285s with just a little trimming to prevent rubbing and I dont see how they do it. I went down to 265/75s because the rubbing was so bad.
