Lift block problem ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crackedchuck, Sep 22, 2022.
  1. Sep 22, 2022 at 3:53 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m confused what the perceived problem is. If I understand you, everything that has been measured is within spec. Is the issue simply that your eyes perceive an imperfection?
    Chew likes this.
  2. Sep 22, 2022 at 3:54 PM
    crackedchuck
    crackedchuck [OP] Member
    charles
    22 tacoma
    lifted /offset wheels
    No .. everyone can see the problem at the garage but no one knows what the actual problem is
  3. Sep 22, 2022 at 3:57 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Part out!
    Mark77 and Darksport like this.
  4. Sep 22, 2022 at 3:58 PM
    gudujarlson
    Minnesota
    My point is that if you all measurements check out, you haven’t identified a problem. I personally don’t trust my eyes in these situations. Does the truck drive fine?
    Chew likes this.
  5. Sep 22, 2022 at 4:05 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Didn’t read all the replies but my “offset” is exactly the same. And I have stock springs, no spacers or blocks. So not sure if they just come like this from the factory on purpose or on accident. My bed definitely isn’t perfectly aligned with the cab
  6. Sep 22, 2022 at 4:15 PM
    crackedchuck
    charles
    22 tacoma
    you have pictures?
    Darksport[QUOTED] likes this.
  7. Sep 22, 2022 at 4:18 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Speaking of rear blocks does anyone have the part number for the OEM half inch lift block for the 2022 Pro?
  8. Sep 22, 2022 at 4:21 PM
    gudujarlson
    Minnesota
    Your meager attempt to hijack this thread will fail. :)
    Chew likes this.
  9. Sep 22, 2022 at 5:12 PM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    Yes. It isn’t as obvious with the stock set up because the tire are set farther in the fenders.
  10. Sep 22, 2022 at 6:16 PM
    Darksport
    Jake
    NE Ohio (Cleveland)
    I’ll take some tomorrow and post them
  11. Sep 22, 2022 at 6:25 PM
    Elliott07
    Elliott07 Well-Known Member
    Elliott
    2017 Super White Tacoma
    Kings, headlights and taillights, 3rd break light, antenna, methods17”, Falken at3 33”, dirt king Long travel, TRD pro grille, Baja designs, custom faves skid plate, fiberglass fenders, archive garage towers.
    Lol, tried to sneak it in
  12. Sep 22, 2022 at 6:41 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    stop using the bodywork to eye the problem. It’s the exact same problem of people using wheel center to wheel arch to measure lift. That’s only valid for the same truck not in between different trucks due to tolerances.
    Measure your wheel hub mounting surface to the frame and leaf pack on both sides. That will tell you exactly where the problem lies. If those are identical on both sides, it’s the bed alignment, if they are different it’s the axle placement, or leaf placement depending on which one is different. This is assuming all your wheels have the same backspacing, again simple to check by measuring that.
    Measure everything suspension wise from the frame and nothing else. (Unless you are trying to identify a bent frame)
  13. Sep 22, 2022 at 6:49 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Super mod sprinter!
    Lt. Dangle likes this.
  14. Sep 22, 2022 at 11:37 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    No but Toytec has some available .
  15. Sep 23, 2022 at 12:04 AM
    #35
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Boy salesmen love you don't they. :crazy:
  16. Sep 23, 2022 at 6:04 AM
    #36
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    A. Either bed is just misaligned
    B. Aftermarket rims? Literally jus swap left to right wheels and see what happens. If aftermarket then they likely come in multiple offsets and you got a mismatched rim.
    C. You would have to be pretty clueless to mess up a rear block install.
    Big tall dave and drizzoh like this.
  17. Sep 23, 2022 at 6:57 AM
    #37
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    It is possible your aftermarket rims while being stamped with the same offset are not (could be mis-labeled) did you measure the wheels for comparison or just check the stamp was the same...just a thought
  18. Sep 23, 2022 at 7:36 AM
    #38
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Yes
  19. Sep 25, 2022 at 6:18 AM
    #39
    crackedchuck
    charles
    22 tacoma
    after mesuring everything myself i found out the differential is just longer on one side .. soo good job toyota .. these 3rd gen pickups do not live up to the tacoma name at all lol
  20. Sep 25, 2022 at 8:26 AM
    #40
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    you're driving yourself nuts with these inaccurate measuring exercises, get out and enjoy your weekend and leave the engineering to the engineers
    (not being snarky,, seriously try it, life is too short with this nonsense)
