Lift block problem ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crackedchuck, Sep 22, 2022.
  1. Sep 25, 2022 at 8:31 AM
    #41
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Loosen the bed bolts and fix it that way. Your bed my be catywhompass.
    OffroadToy likes this.
  2. Sep 25, 2022 at 8:32 AM
    #42
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Post pics of your rear axle and surrounding area. Let’s see your lift blocks and how it all looks together.
  3. Sep 26, 2022 at 1:46 AM
    #43
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Adjust the bed, 6 bolts to loosen and move it a bit then call it the day.
  4. Sep 26, 2022 at 6:39 AM
    #44
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    This makes zero sense and has nothing to do with what's going on. Your truck is within spec. There is also some tolerance when you bolt up the rear axle so if it isn't the bed you could likely loosen the ubolts, shift the axle a bit, and tighten everything down and get it centered better.
    VaToy and Chew like this.
