Lift Checklist
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bradw3451, Jul 25, 2011.
  1. Jul 25, 2011 at 10:57 AM
    Bradw3451
    Bradw3451 [OP] Member
    Brad Wrubel
    Denver, CO
    To be as up front as possible, I know nothing about lifts. I have read through about every lift inspired post on this website and have decided on the following:
    OME Suspension Lift Kit, 885 Coils, Top Plate Spacers, Complete Rear OME CS047R Springs with U-Bolts and Light Racing Upper Control Arms
    With that said, is there anything else that I should add? For that matter, would you change anything out?
    To give you a little information, this will be my DD but I do fish and hunt so off road capabilities, although not "wheeling" are important.
    Thanks!
  2. Jul 25, 2011 at 11:11 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Looks good to me! Exact same setup I will be getting here in a few short months...
  3. Jul 25, 2011 at 11:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What are you putting the lift on and what's already on it? (ie, double cab, access cab, is it armored, skids, plate bumper, winch, etc). That info would be useful.
  4. Jul 25, 2011 at 11:37 AM
    Bradw3451
    Brad Wrubel
    Denver, CO
    Haven t picked the truck up yet but it will be a 2007+ Double Cab Short Bed, no armor, plate bumper or winch. Maybe a pre-runner looking light bar up front.
  5. Jul 25, 2011 at 11:43 AM
    Pugga
    Massachusetts
    Does the rear kit come with shocks, drive shaft spacer and shims? They may not be needed but they're good to have on hand if you develop vibes and they're relatively cheap if you buy them with the kit.
  6. Jul 25, 2011 at 11:46 AM
    Bradw3451
    Brad Wrubel
    Denver, CO
    No, it doesn't have those included but I will definitely pick them up. Thanks for the heads up!
    My plan is to take the vehicle straight to get all of this installed the moment I pick it up.
  7. Jul 25, 2011 at 12:08 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  8. Jul 25, 2011 at 12:10 PM
    OZ-T
    Peter North
    British Columbia
    Install the OME CB drop ( fitting kit FK29 ) when you install your lift , wait on the diff drop
  9. Jul 25, 2011 at 12:16 PM
    Pugga
    Massachusetts
    Did you put this on your truck? I bought the CB drop kit and haven't installed yet because it looked like it would make straighten out the shaft between the CB and diff, but create a new issue between the transfer case and CB :confused:
    I'm assuming yours is working out well though?
  10. Jul 25, 2011 at 12:21 PM
    OZ-T
    Peter North
    British Columbia
    Yes , I installed it with the lift .
    I added no vibes by installing my lift .
  11. Jul 25, 2011 at 12:21 PM
    Pugga
    Massachusetts
    Damn... I guess I should put that thing on. It's been sitting in my cup holder for months :eek:
