LIFT GURU's....HELP PLEASE>>>
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04TrDeeZ, Oct 24, 2010.
  1. Oct 27, 2010 at 9:39 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  2. Oct 27, 2010 at 9:52 AM
    764mike
    764mike Well-Known Member
    NJ
    2008 Toyota Tacoma Double Cab
    If you have the rear Leaf TSB done do you still need the AAL.
  3. Oct 27, 2010 at 10:06 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    There's not leaf TSB for first gens...
  4. Oct 27, 2010 at 10:56 AM
    Jet
    Jet Well-Known Member
    Jet
    North Texas
    2024 Off-Road Bronze Oxide
    Looks like you are in Dallas. Contact Jacque at TRD Parts4U (http://www.trdparts4u.com/Scripts/default.asp) they are part of Toyota of Dallas - very helpful and very good prices on OME. 972.852.0105
  5. Oct 27, 2010 at 11:11 AM
    764mike
    NJ
    Sorry I just noticed he had an 04. How bout for a 2nd Gen. With front 5100's will I need a AAL if I had the TSB done in the rear.
  6. Oct 27, 2010 at 4:16 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im looking to do the same. I have about a 1.5" lift in the back due to an AAL. Im looking to change out the aft shocks with 5100's at 1.5" and use 5100's up front set at 1.5".
    Anything special I need to do/buy besides the shocks? What do you mean by "new UCA's"?
  7. Oct 27, 2010 at 4:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    UCA's = Upper Control Arms. After market UCA's are needed to get the alignment back in check if lifting 2" or higher.
  8. Oct 27, 2010 at 4:27 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Got it thanks. I dont plan on more than 1.5" Im looking at the Old Man Emu 881 up front and Bilstein 5100's in the back. Any suggestions or critics?
  9. Oct 27, 2010 at 8:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The OP was looking to spend $500. :eek: You've probably exceeded that by a factor of 4 at least.
  10. Oct 27, 2010 at 9:09 PM
    pittim
    Pennsyltucky
    Boujee Prius
    yeah, but your setup was what, $2500 about?
    I'm sure if he was willing ot save up for Resi's, he wouldnt have made the tread.
