Lift height with Eibach's vs 885's please confirm
Discussion in 'Suspension' started by NiceTaco, Nov 19, 2012.
  1. Nov 19, 2012 at 9:25 AM
    NiceTaco
    NiceTaco [OP] Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Just looking for someone to confirm lift heights achieved with either spring. I have heard and seen different things. I am not talking with top plate spacers or anything just straight shock spring combo... I wanna pull the trigger!
    5100's with Eibach's @0.00
    5100's with Eibach's @0.85
    5100's with OME 885's @0.00
    5100's with OME 885's @0.85
    truck is a 12 Dbl Cab TRD Sport.
    Thanks!
  2. Nov 19, 2012 at 9:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    These are approximate for a double cab 4x4.
    5100's with Eibach's @0.00 = 1.6"
    5100's with Eibach's @0.85 - 2.5"
    5100's with OME 885's @0.00 = ~2.5"
    5100's with OME 885's @0.85 = Not advised, could put you over 3" of lift and your CVs will hate you. People have done this as the coils sagged or if they have heavy loads such as a winch or plate bumper though.
  3. Nov 19, 2012 at 9:34 AM
    Large
    Large Red
    5100 & 885s 2.5"
    With bumper 2" (brute force)
    Bumper & winch 1-5/8" (xrc8)
    Dcsb 4wd.
  4. Nov 19, 2012 at 9:44 AM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    This is my setup with a DCSB TRD Off-Road 4x4. The advertised lift was 1.6" on average. And I got ........ [drumroll].......... about 1.6".
    Picture (note just TSB leafs in rear):
    Sits just about level. Rear is maybe 0.5" higher at most.
  5. Nov 19, 2012 at 9:57 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    See I only wanted about 2" and was told eibachs and 5100's @.85 would be around 2.25... I don't want new UCA's
    I don't think 1.6 will be enough...
  6. Nov 19, 2012 at 10:15 AM
    nytro
    nytro Active Member
    NorCal
    2011 DCLB
    Front:Bilsteins 5100 with 884's. Rear: Bilsteins 5100, tsb and AAL.
    884's should give you what you're looking for.
  7. Nov 19, 2012 at 10:16 AM
    Pugga
    Massachusetts
    x2. Same spring rate as the 885s but about 1/2" shorter.
  8. Nov 19, 2012 at 1:51 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Interesting. So 5100s mounted to 885s with an offroad bumper will give you about 2"? Are these the same numbers on an AC?
  9. Nov 19, 2012 at 3:40 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    So 5100's with 884's will give me what at either setting?
    Would the 1.6 with the eibachs be basically like doing stock springs with 5100's @1.75?
    How hard is it to adjust them? If I went 1.6 and wanted more do you have to take them all apart again to go to 2.5? I am paying a shop for install so....
  10. Nov 20, 2012 at 2:45 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    5100's @ 0 will give you two inches off the bat, settling at like 1.75" (don't quote me on that).
    If you go stock spring route and crank em up to the top setting you'll kick yourself....actually your truck will kick you, literally. Its stiff as a dead cat.
    Yeah you have to take them apart because all the pressure rests on that spring seat, which rests on the adjustable clip. You have to at least relieve the coil of its duty and this usually means taking it all apart. Shop shouldnt charge much considering its easy as pie, plus you'll want an alignment with the added height so you'd have to pay em eventually.
  11. Nov 20, 2012 at 3:45 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    ^^^ are you talking with the 884's I Gould see that? I'd like to hear from someone who hopefully has that setup. I want 2" not 2.5 so that why I am looking at 884's
    I wouldn't not crank the 5100's to the top (2.5) but I would go 1.75 and that seems to be a very common setting and people love it on here. Most setting it rides better than stock at that setting.
  12. Nov 20, 2012 at 8:42 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    After talking to Toytec they suggested that I set the 5100's to 0 with the Eibach spring and use there 1/2" top plate spacers to get around 2"
    Anyone running this? or think this will work good for me?
  13. Nov 20, 2012 at 8:55 AM
    Pugga
    Massachusetts
    Talk to Mattmxracer, he just installed 884's on his Access Cab.
    Personally, I'd rather go with the 884's. I have Eibach coils and I think they're a little stiff. It's not bad enough for me to even consider changing, but if I could do it over again, I'd probably go OME.
    What Toytec is suggesting will work and you won't have any issues with that setup. The reason they are likely recommending that setup is that the Eibach coils are meant to be paired with 5100 shocks, OME coils are meant to be paired with Nitrocharger shocks. There is no harm in mixing them but from a vendor's point of view, they want to keep like products together.
  14. Nov 20, 2012 at 9:13 AM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    Say what
  15. Nov 20, 2012 at 9:15 AM
    Pugga
    Massachusetts
    He was responding to the amount of lift gained with 884's, at least I hope that's the case... :rolleyes:
  16. Nov 20, 2012 at 11:18 AM
    nytro
    nytro Active Member
    NorCal
    2011 DCLB
    I have 884's on 5100's set at 0 on a DCLB.
    I have been measuring it constantly, but there is not one bit of level ground in my area where I can get a consistent measurement.
    I have gotten a measurement as high as 2.5" and as low as 2".
    Most of the measurements have been in the 2.25"-2.375" range.
  17. Nov 20, 2012 at 11:40 AM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Glad someone asked this looking into OME 884 and 885 also for my 2012 DCSB OR 4x4. I think I'd like to go with the 885 so I get 2.5 at 0. Is the tsb enough to make it close to level? Slight rake up front is fine with me.
  18. Nov 20, 2012 at 11:48 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I got .25 inch lift when i installed 885x on 5100 at 0 over what the eibach at .85 on 5100 gave me.
  19. Nov 20, 2012 at 12:14 PM
    OZ-T
    Peter North
    British Columbia
    885x , no top plate spacers got me 2 1/2" of lift on my DCLB 4x4
  20. Nov 20, 2012 at 12:24 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    I have Eibachs on 5100's set at .85 and the 3/4" spacer...
