Lift Help???
Discussion in 'Suspension' started by Jeffman1991, Oct 1, 2008.
  1. Oct 1, 2008 at 5:31 PM
    Jeffman1991
    Jeffman1991 [OP] Active Member
    Jacksonville, Florida
    '08 Blue Pre-Runner TRD
    Standard Profile Black Toolbox, Straight Pipes with Borla Tips, Secondary air filter removal, K&N Air Filter, CB Radio with 4 foot whip, 50 watt PA, two 8 inch JL Subwoofers, Pioneer Headunit, Jensen 400 watt speakers all around. 3 inch lift coming soon.
    Ok so I have a '08 TRD Sport Double Cab 2wd. I want to lift it at least 3 inches for cheap. At most $1000 installed. I want to fit at least 33's. The bigger the better. I know lift blocks are the devil but a 3 inch leveling kit and 3 inch blocks sound very appealing with my high school student budget. Please give me some setup suggestions with prices and pictures. Thanks!!!
  2. Oct 1, 2008 at 5:53 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  3. Oct 1, 2008 at 6:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    whatever you do.......dont go with rear blocks....go with rear aal's!!! the ride will be so much nicer and you wont have any axle wrap like the blocks have the potential to do. i think a good toytec 3 inch kit will be right up your alley!!:)
  4. Oct 1, 2008 at 6:19 PM
    Khaos
    Khaos Big Member
    Bryant
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    x2 on what Will said. Avoid the blocks, get an AAL. If you can afford it, go with OME coils up front instead of the 3" spacer.
    3" Coil lift with AAL $299.
    3" Spacer kit with AAL for $239
    For the best ride, you could also get some OME shocks from Toytec.
