lift help
Discussion in 'Suspension' started by PPD934, Oct 20, 2009.
  1. Oct 20, 2009 at 11:11 AM
    PPD934
    PPD934 [OP] Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    I know its another OME lift question but I am getting many different answers.. Im going to go with the 885 coils and the OME shocks. My question is of you who have this how much lift did you get. Im looking for something around 2.75 to 3 inch. I hear some who have got close to 3 without the top plate spacers and so who had to use them to get anywhere near 3. Im a 06 DC TRD 4x4. NO extra bumper or anything... what have you all got..
  2. Oct 20, 2009 at 11:27 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Where in western Kentucky are you? My folks are in Mayfield, and I spend about 3 months out of the year there. Good luck with the lift question. This has been beaten to death in other posts. Best of luck!!
  3. Oct 20, 2009 at 12:01 PM
    PPD934
    Western Kentucky
    im about 15 mile from mayfield.... man i wish you was here all the time... I haven't found many people down here who are into this like it seems in the western part of the country,, I live off KY 131 that run on 80 into mayfield.. Reidland ifyou are familiar
  4. Oct 20, 2009 at 12:06 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    for a dc get the 885's. you should sit right at 3" after settling. get the spacers with the 885's just in case, if you do not need them just return them
  5. Oct 20, 2009 at 12:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  6. Oct 20, 2009 at 12:10 PM
    NraFan
    JT
    SoCal
    My folks are off State Route 303, just outside of Cuba.
  7. Oct 20, 2009 at 12:56 PM
    PPD934
    Western Kentucky
    so meteoraman2514 and chris wont i have to take them apart to use the longer top bolts if its not tall enough.... or can i install the long bolts even if i don;t use the top plates....
  8. Oct 20, 2009 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can install the longer studs even if you dont use the top plate spacers.
  9. Oct 20, 2009 at 1:01 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    got 3" from the 885's and top plate spacer with 5100's set @ zero
  10. Oct 20, 2009 at 1:10 PM
    PPD934
    Western Kentucky
    ok that helps alot i was worried i would have to tear them down twice if i tried them without the spacers and then with. To use the longer bolts.... thanks again...
