Lift install sway bar question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Jul 11, 2020.
  1. Jul 11, 2020 at 12:44 PM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I don't think I did anything wrong but I don't see any way to reconnect the sway bar. It's also rubbing on the spindle or real close. Any ideas? Or with this lift do you need to remove it?
    t0nyvalenzuela likes this.
  2. Jul 11, 2020 at 12:46 PM
    doorsidedown
    doorsidedown Well-Known Member
    unhook it where the u-shaped brackets bolt into the frame, then put the links (in your picture) in first. Tighten the bolts by hand and then put the brackets back on?
  3. Jul 11, 2020 at 12:48 PM
    sleazy seagull
    sleazy seagull Well-Known Member
    ‘20 TRDOR DCSB
    Should line up when the suspension isn't full droop. You could either do the above, or wait till the truck is on the ground. I have the same front coils and I have my sway bar installed. No rub or other issues.
  4. Jul 11, 2020 at 12:50 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Do what is mentioned above or just leave it off for a little more articulation. Took mine off a few years ago and the body roll isn't bad at all. But I'm also not doing any high speed cornering.
  5. Jul 11, 2020 at 1:00 PM
    OdiN1701
    Colorado
    Looks like it needs to turn down. I'll get the other side disconnected and see.
  6. Jul 11, 2020 at 1:19 PM
    OdiN1701
    Colorado
    Yup it was just bound up with the other side.
    doorsidedown likes this.
  7. Jul 11, 2020 at 2:28 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Post pics when done
  8. Jul 11, 2020 at 5:07 PM
    OdiN1701
    Colorado
    Something seems off...
    :D
    I'll put the leaf packs on tomorrow.
    The UCA through bolt on the passenger side was a huge PITA. I had to bend a ton, still wasn't getting it. Ended up hammering it through with a pry bar both ways. They should have had a bend in the body panel there for the bolt.
    I'll have to measure after the leaf pack but it seems the front is like 3.5" higher. :confused:
    71tattooguy[QUOTED] likes this.
  9. Jul 11, 2020 at 5:11 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    Was this before you finished the other side?
  10. Jul 11, 2020 at 5:15 PM
    OdiN1701
    Colorado
    Yeah
  11. Jul 11, 2020 at 5:25 PM
    TacoPharm
    Phil
    San Diego
    Edit: Didn’t read far enough that you figured it out
  12. Jul 11, 2020 at 5:39 PM
    OdiN1701
    Colorado
    Yeah things are different when the instructions are from guys doing it on a lift.
  13. Jul 11, 2020 at 6:32 PM
    OdiN1701
    Colorado
    Ok so it's about 24" center of hub to the fender. Seems similar to what others are at.
  14. Jul 12, 2020 at 5:20 PM
    OdiN1701
    Colorado
  15. Jul 12, 2020 at 5:26 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Looks good. Now time for some scs and 285’s.
  16. Jul 12, 2020 at 5:31 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Looks awesome
  17. Jul 12, 2020 at 5:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I cut the bolt heads in-situ with an angle grinder, then installed new bolts going in from the rear. Though on the driver's side, a lot of fuel lines had to be unclipped. This is the cleanest way but costs $30-$50 extra for two bolts.
  18. Jul 12, 2020 at 5:37 PM
    thaiandAn88
    thaiandAn88 Well-Known Member
    Anna
    2018 Toyota tacoma
    Is this a 3” to the front?
  19. Jul 12, 2020 at 6:25 PM
    OdiN1701
    Colorado
    What's scs?
  20. Jul 12, 2020 at 6:26 PM
    OdiN1701
    Colorado
    Might be, but I'm gonna hang a bumper and winch off it.
