Lift is installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Infra, Jun 27, 2010.
  1. Jun 27, 2010 at 8:53 AM
    Infra
    Infra [OP] Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Yesterday we installed my Toytec Ultimate lift with Dakar leaf springs and LR UCA's. It looks damn good if I do say so myself....:D
    Going to crank the coilovers up a little more and then will take it to get it aligned monday. 17x9 Ballistic Offroad 814 with wrangler duratrac's 285/70/17. I have serious rubbing issues L & R front when turning and going forward or turninig and going in reverse. Any advice or tips on how to deal with this?
  2. Jun 27, 2010 at 8:54 AM
    Infra
    Az
    Yes I took the pics as I was about halfway through removing the bedside decals....
  3. Jun 27, 2010 at 8:55 AM
    tbturner47
    tbturner47 Well-Known Member
    Hickory, NC
    '16 Barcelona Red TRD Off Road
    pure secks
  4. Jun 27, 2010 at 9:04 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    looking really good...congrats bro...:D
  5. Jun 27, 2010 at 9:06 AM
    cgs2k2
    cgs2k2 old man
    Damnnnn looks great! Those rims are awesome! I'm not a fan of the "4x4" badge, but that's just me. As for rubbing, I'd say do some trimming and/or get some spacers. But I don't have first hand experience with that issue, so I'm sure somebody more knowledgeable will chime in!
  6. Jun 27, 2010 at 9:08 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Looks great! When you get your alignment, you may have to get your caster set above 3 degrees. This will push the tires forward away from the back of the wheel well. i assume that is where you are rubbing.
  7. Jun 27, 2010 at 9:13 AM
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
    Beautiful!
  8. Jun 27, 2010 at 9:39 AM
    Infra
    Az
    you sir....are correct! I am rubbing on the rear of the front wheel wells. I guess I need to do some trimming.....but not sure how to go about it :confused:
  9. Jun 27, 2010 at 9:51 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Cut the cab mounts, cut the inner fenders and shave off some things as well.
  10. Jun 27, 2010 at 10:32 AM
    Dr. Pepper
    Dr. Pepper Well-Known Member
    Tampa, Florida
    08 PreRunner SR5
    Looks good man. Idk what you would need to trim though...lol
  11. Jun 27, 2010 at 10:47 AM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    Infra...who's side-step bars and bumper guard are you sportin'? They look good...
  12. Jun 27, 2010 at 10:59 AM
    polansky568
    polansky568 Member
    I have the rubbing issue with no lift and 265/70r17s. I've found there is no way to permanently get rid of it. If you look behind the tires in the front two wells, there is a plastic square sticking out. My tires would rub up on them, create friction, and then slowly turn the plastic into flaps, which the tires would then rub up on, and sound a hundred times louder. So i would regularly trim the flaps as they came about.
    Now though, I got so sick of it one day, i trimmed all the plastic off the back, and BAM, complete quietness unless i turn hard into a driveway cuz it pushes the tires back. I was so excited. It lasted for three months, now its back :(
    It's not too bad now though, just bad at turning into driveways and gas stations at highish speeds. I'd save trim the plastic, you'll enjoy the next few months :D
  13. Jun 27, 2010 at 11:39 AM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    looks a lot like Avid stuff to me, could be wrong though, not like it'd be the first time :D
  14. Jun 27, 2010 at 11:41 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    I like the blacked out badging, is it just gloss black paint ? Looks almost gunmetal or black chrome.
  15. Jun 27, 2010 at 2:50 PM
    Infra
    Az
    Thanks Sullyman :thumbsup: Correct. I have a light bar and step bars from Avid Offroad. Once they were prepped I had them powder coated black wrinkle.
    Thanks...I used a flat black krylon fusion from Home Depot. I may take them off again and sand them down and then use some type of do it yourself bedliner on them. I have only had the badges painted and on the truck for about 2 weeks now and all of them except the 4x4 badge have chips in the paint already, some in several places.
  16. Jun 27, 2010 at 2:54 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Thanks...I used a flat black krylon fusion from Home Depot. I may take them off again and sand them down and then use some type of do it yourself bedliner on them. I have only had the badges painted and on the truck for about 2 weeks now and all of them except the 4x4 badge have chips in the paint already, some in several places.[/QUOTE]
    The bedliner is a PITA the keep looking good. Had it on my bumpers and grill surround of my first gen. looked cool touching it up got really old after awhile.
  17. Jun 27, 2010 at 2:59 PM
    David10MGM
    David10MGM Active Member
    David
    Tennessee
    10 PreRunner TRD Off Road MGM
    Camburg spindles, bilstein 5100's @ 1.75, All-pro 3in leaf, 1.5in block, 5125's
    Your truck looks awesome!!! Can't wait to get mine done. I love the light bar.
  18. Jun 27, 2010 at 3:04 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Sexy like!
  19. Jun 27, 2010 at 3:15 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Keep an eye on your CV boots after you crank those coils. I ran into this problem with my Ultimate kit and blew a CV boot and axel on my 09 because I had the CO's set too high. I had about 1/2 - 3/4 of an inch left on my collers. The truck looked great but did not ride all that great after adjustment. I have since sold it for a 4 1/2 - 5" RCD kit.
  20. Jun 27, 2010 at 6:29 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Looks awesome!! where did you get the front bar and sliders?
