Lift kit advice 23 OR
Discussion in 'Suspension' started by 98_3RZ_NIC, Feb 12, 2023.
  1. Feb 12, 2023 at 2:09 PM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Best lift kit for a 2023 OR that doesn’t see any crazy off roading or bumps. Mainly street driving but want it to look good and fit 285/70/17. Any advice is appreciated as always.
  2. Feb 12, 2023 at 9:31 PM
    Skylarc
    Skylarc Member
    Skylar
    2014 Tacoma TRD Sport
    Bilstein 6112/5100. Best bang for your buck imo.
  3. Feb 12, 2023 at 9:38 PM
    MGMDesertTaco
  4. Feb 12, 2023 at 10:31 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    I’ve ran both 5100 and 5160 in the rear. If you’re not going offroad, the reservoir isn’t necessary imo
    98_3RZ_NIC[OP] likes this.
