Lift Kit, am I missing anything?
Discussion in 'Suspension' started by ArMarine04, Oct 27, 2013.
  1. Oct 27, 2013 at 7:26 PM
    ArMarine04
    ArMarine04 [OP] Well-Known Member
    Alan
    Beaufort, SC
    So I'm getting myself a lift for Christmas and have chosen the below option. What I'm asking is people with experience, in your opinion are there any other odds and ends that I'm over looking that I should get to go with this lift?
    extended front and back brake lines.
    Front Swaybar Relocate Kit for 07-09 FJ, 05 & UP Tacoma & 03-09 4Run
    Front Top Plate Spacer (One - 1/4") x2
    3" lift kit with Bilstein 5100 Height Adj. Coilovers
    View/Hide options
    Rear lift options: CS047R Daker complete leaf springs
    Front diff drop kit: Add (4x4)
    Rear shock options: 5160 Rear Reservoir shocks
  2. Oct 27, 2013 at 7:28 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Make sure they send you U-Bolts.
    What springs are going onto the Bilstein 5100's? And they are not coilovers, they are just struts.
    If you're ordering from Toytec, make sure the rear shocks are long enough for the new springs.
  3. Oct 27, 2013 at 7:37 PM
    DevL
    DevL Well-Known Member
    Front brake lines?
    Diff drop on an 05+?
    Top plate spacer with a 5100 lift?
    Sway bar reloaction kit with stock springs?
    You dont need any of these.
    Perhaps a carrier bearing drop for the rear would be more useful.
  4. Oct 27, 2013 at 7:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Looks like you are going for a full 3" lift, in which case you will want new upper control arms, otherwise you won't have enough caster.
    Diff drop does more harm than good. Do the boot slide mod instead.
  5. Oct 27, 2013 at 9:05 PM
    ArMarine04
    Alan
    Beaufort, SC
    Below is everything it comes with and I want to upgrade to the Dakers in the back with the 5160 shocks.
    The top front spacers are in case it doesn't sit completely level, I've seen a lot of trucks on here with a 3 inch lift and have a little rake to them, and I want it as level as possible. they aren't expensive and if its level without I won't use them.
    Complete 3" lift kit for 2005 & UP Tacoma with Bilstein 5100 Height Adjustable front shocks
    INCLUDES:
    Bilstein 5100 height adjustable front shocks
    Toytec/Eibach 112620 front coils
    Fully assembled with Toytec Aluminum top mount and Urethane bushings
    Preset at 3" Lift (Lift heights may vary depending on how much front weight you have installed on your vehicle)
    Rear options: select one below
    -----TAC-AL - ToyTec Rear "long" add-a-leafs featuring anti friction pads for quiet ride
    -----TAC-AL-TSB for Tsb & 4 leaf Toyota springs
    -----BK-15 1 1/2" rear block kit
    -----CS047R Complete OME Dakar springs include bushings and additional shipping to the 48 states, Alaska and Hawaii will have additional shipping due; we will contact you with the additional amount due. price is for set of 2
    Also includes:
    -----Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
    -----TT-RS - rear axle degree shims for proper pinion angle alignment
    -----UB-4 - (4) new rear ubolts
    ** SOME Tacoma models with a total of 4 leafs (3 main leafs, 1 overload) in the rear leaf pack require our TSB AAL- Part # TAC-AL-TSB. Please count how many leafs you have before ordering **
    * Choose below to upgrade standard Bilstein 5100 rear shocks to Bilstein 5160 Remote Reservoir shocks *
    **Not recommended for reg cab Tacoma without additional front weight
  6. Oct 28, 2013 at 5:34 AM
    ArMarine04
    Alan
    Beaufort, SC
    Anyone else?
  7. Oct 28, 2013 at 10:02 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Carrier bearing drop. Make sure you get the additional bushings needed for the rear eyes of the Dakar springs.
  8. Oct 28, 2013 at 10:04 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Thats the same lift I have. Im very happy with it.
  9. Oct 30, 2013 at 8:21 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    What is the "boot slide mod"? Or where can I find it?
    Thank you
  10. Oct 30, 2013 at 9:29 AM
    ArMarine04
    Alan
    Beaufort, SC
    Someone correct me if I'm wrong but it's where you loosen the clamp furthest from wheel on the CV boot and slide it toward the engine to keep the fins from bunching up and rubbing on itself and wearing out. Of course that issue only occurs with a lift.
  11. Oct 30, 2013 at 9:35 AM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Do you want a u-bolt flip kit?
  12. Oct 30, 2013 at 9:42 AM
    Mademan925
    Nick
    Discovery Bay, CA
    I took out my diff drop for my skids. I also got a long Ubolt flip kit.
