Lift kit mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoseH89, Oct 29, 2020.
  1. Oct 29, 2020 at 11:01 PM
    JoseH89
    JoseH89 [OP] Member
    Jose Herrera
    2015 Black Tacoma SR5
    Side Steps
    I just did a 3” lift kit on my 15 Tacoma but now it’s making a scraping noise and my Stab control light came on. Help would be greatly appreciate it
  2. Oct 30, 2020 at 4:36 AM
    Muddinfun
    Muddinfun Well-Known Member
    WTF is a stab control light?
    Juisebocks likes this.
  3. Oct 30, 2020 at 4:46 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Stability Control.
    OP needs to look up the OBDII jumper sequence to relearn the stability control.
    As for the scraping noise, OP did you get an alignment? Dis you put on larger tires without changing the control arms?
    When do you hear the scraping? All the time? Only at full lock? Only on impacts etc?
    What lift kit?
    More details needed.
    Larzzzz and Muddinfun[QUOTED] like this.
  4. Oct 30, 2020 at 4:50 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
  5. Oct 30, 2020 at 5:28 AM
    JoseH89
    JoseH89 [OP] Member
    Jose Herrera
    Side Steps
    Stability control Muddin.
    right after I installed it clearly sounds like a brake pad is stuck or such but I am not too sure. And it does it when I’m driving and I am taking in today to get it it’s alignment.
    Muddinfun likes this.
  6. Oct 30, 2020 at 6:30 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Welcome to TW. What size tires are you running?
  7. Oct 30, 2020 at 6:44 AM
    JoseH89
    JoseH89 [OP] Member
    Jose Herrera
    Side Steps
    Wattapunk, I have 285/75r16 I had these on before the lift kit was installed had them for a year
  8. Oct 30, 2020 at 7:35 AM
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    Might’ve pinched on of your VSS wires ..
  9. Oct 30, 2020 at 10:00 PM
    JoseH89
    JoseH89 [OP] Member
    Jose Herrera
    Side Steps
    Thanks guys once I took in for the alignment they saw the brake plate was slightly moved and they fix it. few thought it was the brake rotors that had got some dust and or pebble after the lift kit was installed
