Lift modification
Discussion in 'Suspension' started by BPZ, Oct 19, 2011.
  1. Oct 19, 2011 at 5:43 PM
    BPZ
    BPZ [OP] Member
    08 Offroad
    3" suspension lift, 3" body lift.
    I noticed a "rubbing" noise from the front end- also felt wrong while driving. I took it to the shop and they replaced the Hub assembly on front axle and the shaft assembly. The shop stated that the lift is jacking my truck up. I am running a 3" suspension lift and a 3" body lift. i have 35's. Is it possible to remove the body lift with size 35's? Would this most likely alleviate the issues? Thanks
  2. Oct 19, 2011 at 5:45 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Sure it's not your tires rubbing? What backspacing are you wheels? Did you trim the fender wells and chop the cab mounts?
    You can't fit the 35's with. 3" lift without and aftermarket front bumper and some fender trimming.
  3. Oct 19, 2011 at 5:46 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    35s with a 3 inch lift probably would result in rubbing
  4. Oct 19, 2011 at 7:27 PM
    05TRDTACO
    05TRDTACO Member
    Justin
    Utah
    2013 Tacoma DC-silver TRD Off-Road
    Fabtech 6" lift, Bilstein 5100 rear shocks, TRD air filter, TRD exhaust, Optima redtop battery, 18% tint all around, debadged, fog light mod, power plugs hot all the time mod, Streamlight Stinger mounted behind seat, Viper 5704v security system and remote start, rear diff breather mod, & auxiliary fuse box
    i have a 05 double cab with a fabtech 6" and 35s and it rubbed on my cab mounts. i bet that is where your rubbing since you only have 3 inches of suspension lift. If its not rubbing there i would guess the tires are rubbing somewhere
  5. Oct 20, 2011 at 2:05 AM
    BPZ
    BPZ [OP] Member
    08 Offroad
    The rubbing was dude to the worn Hub assembly and shaf assembly. This rubbing has been fixed. The reason I was inquiring about the lowering was that I was told by a couple shops (Toyota) that the lift is stressing out the vehicle. Not sure I want to trim but possibly replace wheeles with smaller size. Can anyone tell me the biggest tires I could run with just a 3" suspension lift-without replacing bumper or trimming? Recommendations on brand? Thanks
  6. Oct 20, 2011 at 2:21 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    If the lift is "stressing" the vehical I don't see how it could be the body lift. How are your cv's? Angels? Boots rubbing in places?
    I think the largest size tire you can run with "NO" trimming is 265-75-16. I know guys run 285/75/16 but thats with trimming and even then offroad you will/could have some rub. Guys like 255-85-16 too. I think you could get away with running them no trimming.
    And tires depends what your doing. Wheeling I suggest the km2.
  7. Oct 20, 2011 at 4:59 PM
    BPZ
    BPZ [OP] Member
    08 Offroad
    Thanks.
