Lift option?
Discussion in '1st Gen. Tacomas (1995-2004)' started by redtaco, Nov 5, 2015.
  1. Nov 5, 2015 at 10:17 AM
    redtaco
    redtaco [OP] Well-Known Member
  2. Nov 6, 2015 at 5:58 AM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    I'd say it depends on what your goals are. Just wanting "a lift" isn't terribly descriptive. That one won't lift 3" if that's your goal. And you can lift the front for "$350" but not do it well. At that height your camber will be off enough that the alignment shop probably can't get it close to spec without more than doubling your budget to first include new upper control arms designed to offset the issue caused by raising it so much.
    Now, at a 2.5" or certainly 2" lift, you could be OK. On the other hand if this is mainly an offroad vehicle the alignment matters a lot less.
  3. Nov 6, 2015 at 6:01 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I will tell you what I tell everyone in the same situation OP, I would NEVER recommend someone put a lift kit on a 35k truck for under $500
  4. Nov 6, 2015 at 6:02 AM
    redtaco
    This is just a street truck no off road at all...looking to run 285/70R17 with no rubbing issues I'm assuming 3" will be what I'm looking for
  5. Nov 6, 2015 at 6:05 AM
    deckeda
    Pretty much every thread I've read where a 3" lift is used, a new UCA was very appreciated. You'd have a lot of positive camber without it, which would not help street handling at all.
  6. Nov 6, 2015 at 6:05 AM
    Fallguy6666
    Fallguy6666 Well-Known Member
    I love it.....I run 2"lift springs and spacers up front....for a total of 4 1/2" up front....my alignment is perfect.and I wheel the ever loving bejesus out of my truck.
  7. Nov 6, 2015 at 6:07 AM
    deckeda
    4.5" lift and perfect alignment. Well OK there you go.
  8. Nov 6, 2015 at 6:08 AM
    geekhouse23
    I still rubbed a little plastic and had to trim..
    2.5"+ you need UCA's
  9. Nov 6, 2015 at 6:09 AM
    Fallguy6666
    Mine has stock control arms.....
  10. Nov 6, 2015 at 6:12 AM
    geekhouse23
    :worthless:
  11. Nov 6, 2015 at 6:15 AM
    Fallguy6666
    On 33's...zero rubbing.
  12. Nov 6, 2015 at 6:17 AM
    geekhouse23
    So you're running stacked lift? Can't say I would ever recommend that..EVER..
  13. Nov 6, 2015 at 6:19 AM
    deckeda
    And I don't want to derail this thread either, but something does not add up here.
  14. Nov 6, 2015 at 6:20 AM
    Fallguy6666
    Springs and spacers.so yeah,I guess you could say its stacked.I don't ever recommend anybody do what I do.it works for me.but that's not what I was referring to.I was making it known that you can lift it 3" and still have a proper alignment done with stock control arms....you will have to find a good shop and not some fancy ass Volvo shop.
  15. Nov 6, 2015 at 6:21 AM
    Fallguy6666
    What pray tell doesn't ad up?
  16. Nov 6, 2015 at 6:22 AM
    geekhouse23
    Could you run 3" with stock UCA's? Yea, sure. Do people do that? Yea.
    Is it highly recommended that you get new UCA's as you approach 2.5" and up? Absolutely.
  17. Nov 6, 2015 at 6:35 AM
    deckeda
    I'm left wondering why you don't recommend it, either.
  18. Nov 6, 2015 at 6:37 AM
    Fallguy6666
    Never said it wasn't recommended... Just in my case it wasn't a necessity.
  19. Nov 6, 2015 at 6:39 AM
    Fallguy6666
    I mud,I hill climb,I bounce off boulders.I run trail roads as fast as possible with a 2.7.lol.will mine break...most definitely.... Will I replace with stock...most definitely.
  20. Nov 6, 2015 at 2:47 PM
    redtaco
    So what would be the recommendation for a street only truck if I wanted to run something close to 33's on 17 inch wheels? I want to maintain a good comfortable ride and I don't mind a little rubbing at full lock but I'm not cutting or trimming anything thanks
