lift or rims and tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eman5pt0, Jul 19, 2011.
  1. Jul 19, 2011 at 9:00 PM
    Eman5pt0
    Eman5pt0 [OP] Well-Known Member
    E
    NY
    until today i was going to save for a set of bilsteins and an AAL, start there and piece together a lift. would i be better off getting a set of rims and tires first ? right now im running the stock 245s and after thinking about it a lot those might look to small with the lift of the truck. opinions ?
  2. Jul 19, 2011 at 9:04 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    4x4? We need more details also about your intentions for the lift. Wheeling or cosmetic?
  3. Jul 19, 2011 at 9:08 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    unfortunately for you...these two things go hand in hand...hard to get a lift and not get ATLEAST new tires..
  4. Jul 19, 2011 at 9:13 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    wheels and tires first
  5. Jul 19, 2011 at 9:16 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Save and get them both together. If you're like me and cant wait for anything, get the lift first. Won't be able to fit the tires on w/o a lift anyways.
  6. Jul 19, 2011 at 9:16 PM
    Maverick904
    Kameron
    Northeast Florida
    If im not mistaken..you can run 265/75/16 on a stock 2nd gen 4x4 or prerunner if thats what you have. if this is the case.. these tires dont look bad once you get it lifted as well.
  7. Jul 19, 2011 at 9:17 PM
    Stohrm
    Stohrm Well-Known Member
    Michael
    Oregon
    05 TRD Sport 6 speed manual
    Truth. That is what I am running right now on my 05. Anything bigger needs a lift/work done to make em fit
  8. Jul 19, 2011 at 9:21 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    You could get wheels and tires first but if you plan on lifting it later then you are probably going to want larger tires after the lift. So you should probably wait
  9. Jul 19, 2011 at 9:23 PM
    Eman5pt0
    E
    NY
    sorry for the lack of info .. i have a 09 4x4 i was looking into 265 70 17s i know they will fit. my plan was to go with the billies and a AAL than save for the rims and tires than coils an UCAs. the end product is basically the toytec ULK. but piece by piece because i cant afford everything at once.
  10. Jul 19, 2011 at 9:25 PM
    Maverick904
    Kameron
    Northeast Florida
    go rims and tires first...cuz the truck will look stupid when you put it up with stock tires
  11. Jul 19, 2011 at 9:34 PM
    cummins6speed
    You can if you save
  12. Jul 19, 2011 at 9:37 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/167652-busted-my-5100-a.html
    read this before buying the 5100's with your AAL :D
  13. Jul 19, 2011 at 9:39 PM
    Eman5pt0
    E
    NY
    well yeah but saving 100 bucks a month isn't going to cut it, id rather save what i can and get some mods little by little
