Lift Performance Question
Discussion in 'Suspension' started by bowhuntingaddict, Jun 2, 2010.
  1. Jun 2, 2010 at 10:28 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I'm new to lifts and no next to nothing about them, and I have a couple of questions. I'm going to be purchasing the toytec 3" lift w/front spacers, and I'm wondering how this will affect my trucks performance (mainly offroad). I would also like to know if anything else needs to be purchased with this lift. I have an 05 LB SR5 tacoma.
  2. Jun 3, 2010 at 9:54 AM
    MooseTX82
    MooseTX82 Moose
    San Diego
    08 TRD Sport 4x4
    Airaid Intake, Magnaflow Exh System, Icon Front Coilovers, TC UCAs, BFG 285s on 17" MotoMetal 951s, ARB Bumper, Hella Running Lights, Alpine CD HU, 6.5 Front JL Audio, 1 10" Kicker powered by Alpine 4 channel Amp
    Its a no brainer that with the added 3" lift you will see better off-road performance. Add some tires to that and you can go alot of places. I took my truck out when it was stock and did some wheeling that was way above its head and it did decent. But when I did that same train with a 3" lift and some 285 BFG AT it was a beast.
    You are also gonna lift the rear too right?
  3. Jun 3, 2010 at 10:08 AM
    bowhuntingaddict
    Yes I'm going to lift the rear too. I wanted to get a suspension lift, but my dad wont let me spend the money on it.
  4. Jun 3, 2010 at 10:19 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    If you do specers, not recommended, go with billy 5100 as well. If your looking for great performance, which spacers will give you next to none, go with a coilover kit. Better ride, better performance, and will not hurt your truck like spacers could, especially since you will be wheeling
    Edit: ignore my first sentence. Ditch the spacers and just go with the billys
  5. Jun 3, 2010 at 10:21 AM
    08pretaco
    az
    Spacers are a suspension lift....
  6. Jun 3, 2010 at 10:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    For $70 more you can get this
    Avoid the spacers if you can..........
  7. Jun 3, 2010 at 4:48 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    just say "NO" to spacers
    esp if you planning on doing some offroad. struts w/ spacers have been known to break going over pot holes. now imagine off road...
  8. Jun 3, 2010 at 6:33 PM
    bowhuntingaddict
    Thanks for all the input, and if you have anymore advice feel free to share. I was also wondering how much it would cost to get this intalled?
    (Would I need new front shocks if I went with the kit with the coilovers?)
  9. Jun 3, 2010 at 9:52 PM
    08pretaco
    az
    Coilovers come with new shocks and install would be free. Find a couple buddys to help with the install its very easy and straight forward especially if you go with the coilover since the springs and shocks are already assembled
  10. Jun 4, 2010 at 1:42 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Yep. To original poster, just go invest $100 on a jackstand, torque wrench, and a metric socket set and do it yourself. Spend a couple hours doing some installation research on here, lots of people have done 'do it yourself' writeups with pictures; ask questions on here after doing some research and we'll help you out.
    There's really only about 7 nuts/bolts you have to deal with on each side after you take the wheel off. No special tricks or skills required and you'll probably learn alot and save $$$ by doing it yourself.
    It's a 'bolt on procedure', just remove remove the stock unit and install the Toytec c/o in the reverse order = 3" lift.
  11. Jun 4, 2010 at 1:47 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    also dont forget to factor in the cost of an alignment afterwards
  12. Jun 4, 2010 at 6:39 PM
    bowhuntingaddict
    So if i bought the $300 lift with the coilovers I would have to buy new front shocks, right?
