Lift Question: Bilstein 5100 or Not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by floydski01, Aug 12, 2020.
  1. Aug 14, 2020 at 3:17 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    floydski01[OP] likes this.
  2. Aug 14, 2020 at 4:45 PM
    floydski01
    floydski01 [OP] Member
    Portland, OR
    2019 Tacoma DoubleCab Limited 4x4 V6 3.5 Black
    Bed cover, running boards.
    Nope. Don't believe I have heard of them.
    I assume you recommend them?
  3. Aug 14, 2020 at 4:55 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Not sure if this for me. But. 6112 Bilsteins. If you reply from a quote it will get you to the right person
  4. Aug 14, 2020 at 5:08 PM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    I'm new on the site and have been reading a lot of different things, however, most of the advice says to avoid spacer lifts because they compress the springs by whatever spacer size goes in and actually make the ride less desirable and harsher than doing a "proper" lift with shocks and coils.
    I understand from my own research (not lifted yet), that the Bilstein 5100's are made to use your existing coils upfront, so you can maybe save a few bucks by not needing new coils. YMMV.
    There is more advice than you can shake a stick at around here, so as others have posted, take your time and do lots of research.
    I'm saving/planning for a Bilstein 5100 lift in the future based on what I'll be doing with my truck. I don't need to spend too much and right now my truck is fine with the factory setup. just my humble, (very) opinion.
    71tattooguy likes this.
  5. Aug 14, 2020 at 5:36 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
