lift question with ome 885's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fletcher007, Nov 28, 2011.
  1. Nov 28, 2011 at 5:50 PM
    Fletcher007
    Fletcher007 [OP] Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    i have 09 dbl cab 4x4. i have the 885's up front on 5100's set at 0. what should the distance be up front from the center of my rim to the bottom of the fender well?? thanks
  2. Nov 28, 2011 at 6:06 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Approx 22 1/2 "
