lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fletcher007, Jul 24, 2011.
  1. Jul 24, 2011 at 9:52 PM
    Fletcher007
    Fletcher007 [OP] Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    I just had the rear leaf tsb done at my local toyota dealer. However, now the rear is about an inch or more higher than the front. I have 5100's up front set at 1.75. I dont really want to take them to the 2.50 setting with the stock coil because the ride is probably a tad on the jarring side. so my question is how is the 5100's with the toy tec or eibach springs when set at 0.
