Lift required for 34's
Discussion in 'Suspension' started by Leonel, Jun 11, 2017.
  1. Jun 11, 2017 at 6:01 PM
    Leonel
    Leonel [OP] Well-Known Member
    San Francisco,CA.
    2017 Super White DCSB TRDOR/6MT
    TC,Ext Kings,U402's,4:88's.Elocker rear,ARB front,etc..
    I have a full set of Kings,fronts with 650 lbs springs,TC uca and Deavers J66 to install , they been sitting in my garage for about a month due to the lack of free time to install them. The plan was to run 285/70/17 and call it a day but I'm kind of debating going to 285/75/17's instead. I know a lot of people claim that the lost of power by going to 33's is hardly noticeable but experience tells me thats BS and I'm probably going to end up re gearing to restore the lost power and at that point will probably go with a bigger tire anyways . I'm trying to avoid doing things twice. What's the minimum lift required to run 34's , what body parts need to be modified and which suspension parts will you change from the ones I already have? I drive a 6 speed manual
    Thanks in advance for any advice
  2. Jun 11, 2017 at 7:02 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Ew don't do 34s
  3. Jun 11, 2017 at 7:56 PM
    Leonel
    San Francisco,CA.
    Why not?
  4. Jun 11, 2017 at 7:58 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Wheel size and offset will determine what will need to be trimmed and how much.
  5. Jun 11, 2017 at 8:01 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Your wheels are/will probably be around 4"-4.5" of backspacing. You'll have to do some trimming but 3" in the front should be fine. Will probably rub if you hit a bump in reverse but small price to pay for bigger tires :D
  6. Jun 11, 2017 at 8:02 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Also curious.
  7. Jun 11, 2017 at 8:04 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    Because it's in between 33 and 35 haha that's my guess
    DustStorm4x4[QUOTED] likes this.
  8. Jun 11, 2017 at 8:19 PM
    Leonel
    San Francisco,CA.
    Method 17x8.5 4.5 backspacing I believe with 285/75/17
  9. Jun 11, 2017 at 8:21 PM
    Leonel
    San Francisco,CA.
    Also shooting for useful suspension not looks
  10. Jun 11, 2017 at 8:24 PM
    Leonel
    San Francisco,CA.
    34's might be a better match for 4:88's on a 6 speed manual
  11. Jun 11, 2017 at 8:25 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Lift doesn't help clear tires unless you limit the uptravel
    FinnJ likes this.
  12. Jun 11, 2017 at 9:33 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    33s with this engine / tranny is enough.
    Unless you regear and all that shit
