lift stack can it be done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jacob381, Mar 31, 2012.
  1. Mar 31, 2012 at 8:42 PM
    jacob381
    jacob381 [OP] Member
    Jacob
    ky
    05 prerunner lift wheels and tires
    can u stack 5100 with spacers too and not crNK 5100 all the way up going on 2005 pre runner would likr to do 5100 on like 1.75 or so
  2. Mar 31, 2012 at 8:46 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  3. Mar 31, 2012 at 8:48 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    you really should not stack lifts, nor a string of words without any punctuation.
  4. Mar 31, 2012 at 8:50 PM
    JDMcQ
    I see that we are not short of assholes, either.
  5. Mar 31, 2012 at 8:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Wuts crammed up your vagina tonight ?
  6. Mar 31, 2012 at 8:52 PM
    tinker_troy
    T R O Y
    WY/SD
    oh and welcome to tacomaworld :wave:
  7. Mar 31, 2012 at 8:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  8. Mar 31, 2012 at 10:24 PM
    jacob381
    Jacob
    ky
    well i need to do new shock i think mine is bent on driver side and i already have spacers so why not put it on lie .85 wit hthe spacer how bad will the ride be then im a mall crawler no offroading here
  9. Mar 31, 2012 at 10:27 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  10. Mar 31, 2012 at 10:29 PM
    NelsonTacoma
    Tucson, AZ
    I have a spacer lift too, but not stacked and don't do any major off-roading. But this is what can happen.
  11. Mar 31, 2012 at 10:31 PM
    jacob381
    Jacob
    ky
    ok then this can i do ome springs and 5100 to get three inches turned on like 2.5 on the 5100
  12. Mar 31, 2012 at 10:32 PM
    OZ-T
    Peter North
    British Columbia
    885's with billies at 0 will get an AC Prerunner about 3"
  13. Mar 31, 2012 at 10:32 PM
    NelsonTacoma
    Tucson, AZ
    That is a common setup. I'm currently saving up for a similar setup so I can ditch the spacers.
  14. Mar 31, 2012 at 10:39 PM
    jacob381
    Jacob
    ky
    well im talking about the ome hd spring about what hight would i sit at with those and 5100 allthe way up and no wander that strut looks bent i bet the spacer may have a lil to do with that contributeing to my terriable tacoma lean that is the main reason i want to do all of this
  15. Mar 31, 2012 at 10:43 PM
    OZ-T
    Peter North
    British Columbia
    Do you have a steel aftermarket front bumper ? If not you don't need the HD (886) springs , you will get 3" with the 885's and billies at zero with a Prerunner AC .
    You are not supposed to run the 5100's with the 886 coils , you would have to get OME shocks for those coils anyway
  16. Mar 31, 2012 at 10:47 PM
    jacob381
    Jacob
    ky
    :)So if i get 885 and turn the billies on like .85 0r 1.0 or something like that i should be close to four
  17. Mar 31, 2012 at 10:50 PM
    OZ-T
    Peter North
    British Columbia
    If you want 4" get spindles
  18. Mar 31, 2012 at 10:52 PM
    jacob381
    Jacob
    ky
    :| hate to pay that for spindels when this would be almost 200 less what will it hurt if i run it that way
  19. Mar 31, 2012 at 11:11 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Upper controller arms, I believe.
  20. Mar 31, 2012 at 11:13 PM
    OZ-T
    Peter North
    British Columbia
    You gotta pay to play
