Lift suggestions for G2 taco — DC/LB 4X4
Discussion in 'Suspension' started by Levelland65, Feb 10, 2013.
  1. Feb 10, 2013 at 9:55 AM
    Levelland65
    Levelland65 [OP] Member
    Jeff
    Wimberley, TX
    Taco 4X4 LB
    I need some help on selecting a lift for my new rig. It's a 2013 Tacoma double cab long bed 4X4.
    A TW member/friend gave me a set of 285/70/17 BFG's mounted on FJC black steel rims (major score). To use these rims I will need a 3" lift (according to the 9000+ threads I have read on TW). Looking for a mid-priced lift solution and have these questions for other members.
    Here are my questions:
    1. Can I mix the Toytec 3" Most Popular lift (apprx. $250) with a set of 4 5100 Billies (apprx. $300.00) to achieve a 3" lift?
    2. If so, What setting do I use on the front shocks (i.e., 0, .85,...)?, and
    3. Will I need additional parts (i.e., spacers, etc)?
    This would be a 3" lift for apprx. $350. To good to be true?
    Thanks!
  2. Feb 10, 2013 at 11:10 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    From what I have read, once you get to the magic 3" , You should get a set on UCA`s to help keep alignment true.
  3. Feb 10, 2013 at 11:11 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    OME 885's with 1/4" top plate spacers and 5100's @0 , 1.5" AAL , rear 5100's
  4. Feb 10, 2013 at 11:16 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Toytec's 3 inch lift does use billies. You can set then to 2.5 inches with stock coils, or set then to .85 with eibach coils, or another option is get old man emu 885s with the billies set to 0. For a full 3" you will need 1/4" top plate spacers. After market UCAs are recomended if you go with 3" of lift. Light racing UCAs are about $375. For a better quality lift you should get coils as well as shocks, then plus new rear shocks and UCAs you are over $1000. So ya $300 is to good to be true unless you are getting blocks and spacers which are not recommended.
  5. Feb 10, 2013 at 6:10 PM
    Levelland65
    Jeff
    Wimberley, TX
    Taco 4X4 LB
    I meant to write $550... to good to be true. For clarification, would I need two 1/4" top spacers or just one for the driver's side? Here's my plan (all suggestions welcomed). I'll be mixing 5100 Billies (at .85) with OME 885's + 1/4" top spacers + Light Racing UCA's for the front. For the rear 1–1/2" Lift rear add-a-leaf with 5100 Billies.
    My mathification:
    1. Toytec: 1–1/2" Lift rear add-a-leaf — $84.99 (set)
    2. Wheeler Offroad: OME 885 coils — $160.00 (set)
    3. Toytec: ¼” Spacers — 2 X $22.99
    4. Downsouth Motorsports: 5100 Bilsteins (front and rear) — $329.00
    That puts me right at $500. + Light Racing UCA's at $300 I'm under a grand. Am I leaving anything out?
  6. Feb 10, 2013 at 6:40 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    About the top plate spacers, with aftermarket coils the truck will lean towards the drivers side because the drivers side is heavier-taco lean. So you either want 1/4 on the drivers side only, or 1/4 on passanger and 1/2 on driver side. The 885s alone should get you 2.5 inches of lift, leave the billys set at 0 with 885s. If you get 1/2" top plate spacers you will need longer studs for the top plate, or else there wont be enough threads left to secure the coilover assembly to the shock tower. Your other option is go with OME nitrochargers instead of billys, this way you can use the OME trim packer, which is a quarter inch spacer that goes below the coil seat on the drivers side, this will help get rid of taco lean and only works with OME shocks. That way you can get 1/4 top plate spacers for each side. I think you will need longer u-bolts and centering pins for the leafs, not sure about this but i belive toytec includes that in a package, you may also want shims in case you develope driveshaft vibrations. Best price i have seen for LR UCAs is 375 shipped from headstrong offroad
    Edit: also remember to keep shipping costs in mind, it might not make sense to purchase from 3 different vendors even if those are the cheapest prices because shipping costs will add up. DSM has free shipping to the lower 48
  7. Feb 26, 2013 at 4:08 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    heres the lift im thinking about getting. this is a 3 in lift right? if i put this lift on will i be siting level?
